Home » Eclipse Projects » Eclipse Platform » question on visible when for command
question on visible when for command [message #334962] Thu, 12 March 2009 10:08 Go to next message
I all ... I'm using eclipse 3.3 - the question is about a command.
I need to enable a command in my popup menu when the selected object is of a
particular type (adapt) and the item as got a property set (example delete
= true)
ok the first part about the object type ...
<visibleWhen>
<with variable="activeMenuSelection">
<iterate>
<adapt
type="xxx.yyy.files.eom.IEOMObjectItem">
</adapt>
</iterate>
</with>
</visibleWhen>
HOW TO ENABLE THE CHECK OF THE PROPERTY ...
with actionset I could use the ObjectState property ... I believe that here
I should use the test property ... but I don't know how to use it
Kar
Re: question on visible when for command [message #334987 is a reply to message #334962] Fri, 13 March 2009 12:43 Go to previous message
> of a particular type (adapt) and the item as got a property set
> (example delete = true)
> <visibleWhen>
> <iterate>
> <adapt
> </adapt>
> </iterate>
> </with>
> </visibleWhen>
> here I should use the test property ... but I don't know how to use it
> Thanks
> Kar
Right, you would use adapt and then test:
<adapt type="xxx.yyy.files.eom.IEOMObjectItem">
<test property="com.example.myObj.delete" value="true"/>
</adapt>
You contribute property testers using the
org.eclipse.core.expressions.propertyTesters extension point and a
subclass of org.eclipse.core.expressions.PropertyTester
PW
Paul Webster
Previous Topic:Bundle update and buddy classloading
Next Topic:key bindings to command and action
Current Time: Thu Jul 17 20:30:25 EDT 2025
Powered by FUDForum. Page generated in 0.69998 seconds
