How to handle changes to workspace outside Eclipse with a Job [message #334957] |
Wed, 11 March 2009 15:14 |
We have a StateCacheJobQueue that extends Job. I looked at:
http://www.eclipse.org/articles/Article-Concurrency/jobs-api .html
I create it with the following snippet:
public void schedule(int jobPriority) {
priority = jobPriority;
StateCacheJobQueue queue = StateCacheFactory.getInstance()
.getJobQueue();
queue.schedule(this);
In the StateCacheJobQueue the run is executed ( see below). It then calls
executePendingJobs(). Is it within this method that I should call my
refreshLocal() on the resource to take into account changes in the
workspace that are not made from within Eclipse.
I don't know where to find the information. If this is not the correct
forum please point me in the right direction.
I am really stuck in this matter so all pointers are greatly appreciated.
cheers,
//Mike
StateCacheJobQueue
* (non-Javadoc)
* @see
org.eclipse.core.internal.jobs.InternalJob#run(org.eclipse.c ore.runtime.IProgressMonitor)
protected IStatus run(IProgressMonitor monitor) {
//synchronized in case build starts during checkCancel
synchronized (this) {
if (monitor.isCanceled())
return Status.CANCEL_STATUS;
// if the system is shutting down, don't update
if (systemBundle.getState() == Bundle.STOPPING)
return Status.OK_STATUS;
try {
executePendingJobs(monitor);
// if the update was successful then it should not be recorded
as
// interrupted
interrupted = false;
} catch (OperationCanceledException e) {
} catch (CoreException sig) {
return sig.getStatus();
* Executes all pending jobs
* @param monitor
* @throws CoreException
* @throws OperationCanceledException
private void executePendingJobs(IProgressMonitor monitor)
throws CoreException, OperationCanceledException {
try {
monitor.beginTask(MESSAGE_QUEUE_NAME, priorityQueue.size());
while (!priorityQueue.isEmpty()) {
checkCanceled(monitor);
StateCacheJob job = null;
// synchronize on the buffer but execute job outside lock
synchronized (priorityQueue) {
if (!priorityQueue.isEmpty())
job = (StateCacheJob) priorityQueue.remove();
// check if buffer was empty
if (null == job) break;
// execute job
if (null != job.getStateCache().getResource()) {
monitor.subTask(Messages
.getString("StateCacheJobQueue.task.refresh")
//$NON-NLS-1$
job.getStateCache().getResource().getFullPath());
job.execute(new SubProgressMonitor(monitor, 1));
} finally {
monitor.done();
FUDForum. Page generated in 0.27386 seconds
