Home » Eclipse Projects » Eclipse Platform » Disable "Build Automatically" for a new product
Disable "Build Automatically" for a new product [message #334952] Wed, 11 March 2009 12:46 Go to next message
I've created a new product based on Eclipse and I want to set the "Build
Automatically" setting off by default, this is, when the product is first
launched and a new workspace is created. And of course, when subsequent
new workspaces are created.
Once the workspace is created, it is the user's responsibility to
enable/disable this setting, but I don't mind. I just care about the
default behavior.
I've found how to do it programatically, but I guess there must be a way
to do it using plugin customization files, settings files or something
similar.
Thank you very much!
Re: Disable "Build Automatically" for a new product [message #334985 is a reply to message #334952] Fri, 13 March 2009 12:37 Go to previous message
There's a pref that controls it, the value stored in
org.eclipse.core.resources.ResourcesPlugin.PREF_AUTO_BUILDIN G
With the pref and the plugin, you should be able to set the default to
false in your plugin_customization.ini file (find the correct plugin to
use as well)
PW
Paul Webster
Previous Topic:Activity : can I use negative lookahead in a patternBinding (i.e "hide every contribution from
Next Topic:Bundle update and buddy classloading
Current Time: Fri Nov 21 04:31:00 EST 2025
Powered by FUDForum. Page generated in 0.03524 seconds
