Home » Eclipse Projects » Eclipse Platform » Activity : can I use negative lookahead in a patternBinding (i.e "hide every contribution from
Activity : can I use negative lookahead in a patternBinding (i.e "hide every contribution from [message #334949] Wed, 11 March 2009 11:45 Go to next message
I'd like to simplify our activity declarations that currently include
activity1 - disabled by default
<!-- exclude anything from the ui.ide plugin -->
<activityPatternBinding activityId="activity1"
pattern="org\.eclipse\.ui\.ide/.*"/>
activity 2 - enabled by default, to show some selected contribution from
ui.ide:
<activityPatternBinding activityId="activity2"
pattern=" org\.eclipse\.ui\.ide/org\.eclipse\.ui\.wizards\.new\.projec t "/>
I'd rather like to have just one binding that means hide everything
except the following ...
something like :
pattern=" org\.eclipse\.ui\.ide/.*(?!org\.eclipse\.ui\.wizards\.new\.p roject) "/>
which isn't working for me, so I'd like to know if it just can't be made
to work ...
cheers
Re: Activity : can I use negative lookahead in a patternBinding (i.e "hide every contribution f [message #334984 is a reply to message #334949] Fri, 13 March 2009 12:33 Go to previous message
it will hide/show whatever matches the pattern. If you can get it to
not patch the pattern with your regex, it should work ... *if*.
Your best bet would be to put a breakpoint or conditional breakpoint in
org.eclipse.ui.internal.activities.Activity.isMatch(String) and see that
the String with the ID you care about is being matched (or not).
PW
Paul Webster
Previous Topic:working sets in "Project References"
Next Topic:Disable "Build Automatically" for a new product
Current Time: Sun Jul 13 17:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
