Home » Eclipse Projects » Eclipse Platform » Creating a "ProgressMonitor mirror" of the status view
Creating a "ProgressMonitor mirror" of the status view [message #334943] Wed, 11 March 2009 02:42 Go to next message
we have a normal Job that does some refreshing ( longer running
calculation recreating a model from input file). That one basically works
fine shows progress in the common places ( bottom right/ Status view /
workbench job dialog). The problem we have now is that in some places we
need to check if the Job is running and if so wait for it to complete.
Ideally while waiting for the job to complete the user should see exactly
the kind of progressbar the statusview is showing. Or at least something
similar. After having finished reading this link
http://book.javanb.com/eclipse-rich-client-platform-designin g-coding-and-packaging-java-applications-oct-2005/ch17lev1se c8.html
it seems o me that the only way to solve that would be to implement a
Progressprovider ourself which unfortunately would kill the workbench's
current Progressprovider ( so the status view)? Can someone verify this
and maybe give some thought input on how to solve the problem. We
definetly do not want to loose the normal workbench handling for the Jobs.
Philipp
Re: Creating a "ProgressMonitor mirror" of the status view [message #334947 is a reply to message #334943] Wed, 11 March 2009 05:26 Go to previous messageGo to next message
I think you may be able to use JobManager.join if you give your Job a
specific JobFamily. JobManager.join should show the fact that there is a
job waiting as a separate progress bar in the same places as usual.
hth,
Steffen
Philipp Simon wrote:
> works fine shows progress in the common places ( bottom right/ Status
> view / workbench job dialog). The problem we have now is that in some
> places we need to check if the Job is running and if so wait for it to
> complete. Ideally while waiting for the job to complete the user
> should see exactly the kind of progressbar the statusview is showing.
> Or at least something similar. After having finished reading this link
> workbench's current Progressprovider ( so the status view)? Can
> someone verify this and maybe give some thought input on how to solve
> the problem. We definetly do not want to loose the normal workbench
> Thanks
> Philipp
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to MDPLE, the 1st International Workshop on
Model-Driven Product Line Engineering
http://www.feasiple.de/workshop_en.html
Re: Creating a "ProgressMonitor mirror" of the status view [message #334950 is a reply to message #334943] Wed, 11 March 2009 12:22 Go to previous messageGo to next message
The JobManager might be one possible way to accomplish this. However
the JobManager is typically used to manage/monitor all jobs in the
system or a job family.
As you are only concerned with one particular job, you might try
installing a JobChangeListener using the addJobChangeListener() method.
There is also a getState() method which you can use to query the state
of the job.
Here are some more links that might be useful:
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/runtime_jobs.htm
http://www.eclipse.org/articles/Article-Concurrency/jobs-api .html
Good Luck
Jay
> complete. Ideally while waiting for the job to complete the user should
> see exactly the kind of progressbar the statusview is showing. Or at
> Thanks
> Philipp
Re: Creating a "ProgressMonitor mirror" of the status view [message #334953 is a reply to message #334950] Wed, 11 March 2009 13:16 Go to previous message
But would that give you access to the progress bar to indicate you are
blocking?
Steffen
> of the job.
> Good Luck
> Jay
>> to complete. Ideally while waiting for the job to complete the user
>> link
>> Thanks
>> Philipp
Previous Topic:Registers view...
Next Topic:Existing problem markers are not displayed
Current Time: Fri Nov 07 14:15:41 EST 2025
Powered by FUDForum. Page generated in 0.02765 seconds
