Home » Eclipse Projects » Eclipse Platform » How does an editor determine a file content type?
How does an editor determine a file content type? [message #334935] Tue, 10 March 2009 13:55 Go to next message
Hi All,
I encountered an issue about how editor determines the content type of a
document.
I use an in-memory object to provide XML content, instead of an in-disk
file. I implement the relative IEditorInput and IDocumentProvider.
The editor can open the XML content properly. However, it can't recognize
the xml content type. Is there anything I missed in setting everything up?
Thank you so much for the help in advance!
Best Regards,
Frank Du
Re: How does an editor determine a file content type? [message #334945 is a reply to message #334935] Wed, 11 March 2009 04:42 Go to previous messageGo to next message
Did you extend content-type extension?
- Prakash
http://blog.eclipse-tips.com
"Frank Du" <du.qixing@gmail.com> wrote in message
news:6d9d93cb63b0863f805f41f3c41319de$1@www.eclipse.org...
> Hi All,
> document.
> Best Regards,
> Frank Du
Re: How does an editor determine a file content type? [message #334951 is a reply to message #334945] Wed, 11 March 2009 12:26 Go to previous messageGo to next message
No, I didn't extend content-type extension. The editing content is from a
in-memory object, instead of disk file. Then we can't define the extension
by using file extensions, right?
Then, what could we describe the input file to the editor?
Thank you so much!
Frank
> - Prakash
Re: How does an editor determine a file content type? [message #334968 is a reply to message #334935] Thu, 12 March 2009 12:46 Go to previous messageGo to next message
Frank Du wrote:
> Hi All,
> a document.
> in-disk file. I implement the relative IEditorInput and
> IDocumentProvider.
> recognize the xml content type. Is there anything I missed in setting
> everything up?
Your document provider must implement
org.eclipse.ui.editors.text.IStorageDocumentProvider and return the
correct content type of your in-memory object.
Dani
> Best Regards,
> Frank Du
Re: How does an editor determine a file content type? [message #335063 is a reply to message #334968] Thu, 19 March 2009 19:01 Go to previous messageGo to next message
Hi Dani,
Thank you for the reply. I tried to debug all related methods in
StorageDocumentProvider class. However, the method is not called during
opening a in-disk xml file. Is there any other class used to determine the
content type?
Frank
> Dani
>> Best Regards,
>> Frank Du
Re: How does an editor determine a file content type? [message #335065 is a reply to message #335063] Fri, 20 March 2009 03:00 Go to previous message
Frank Du wrote:
> Hi Dani,
> during opening a in-disk xml file.
Note that this only works for editors based on the platform.text framework.
Dani
> Is there any other class used to determine the content type?
> Frank
>> Dani
>>> Best Regards,
>>> Frank Du
Previous Topic:how to specify GTK?
Next Topic:Localizing about.html
Current Time: Sun Nov 23 10:12:46 EST 2025
Powered by FUDForum. Page generated in 0.04443 seconds
