Home » Eclipse Projects » Eclipse Platform » LTK copy refactoring
LTK copy refactoring [message #334922] Tue, 10 March 2009 09:51 Go to next message
I need to do some refactoring on certain actions in the Project Explorer
for the copy and paste action but can't seem to get it to work. I have
successfully used the rename, move and delete refactoring extension points
in the LTK (i.e. org.eclipse.ltk.core.refactoring.renameParticipants) but
when I try to use the org.eclipse.ltk.core.refactoring.copyParticipants
extension point nothing happens. I can't find any documentation regarding
the use of copyParticipants and/or the createParticipants extension
points.
Does anyone know what triggers the copy & create participants?
Also, does anyone know how I can contribute a participant for refactoring
when a Copy & Paste Action is executed from both the menu/keyboard
shortcuts and RMB context menu?
Re: LTK copy refactoring [message #334932 is a reply to message #334922] Tue, 10 March 2009 12:55 Go to previous messageGo to next message
The IDE actions (i.e. not in the Package Explorer) only implements Move,
Rename, and Delete.
You've done the right thing, open a bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267851
AFAIK there aren't plans to work on this, although I'll always consider
patches (it's not trivial, though :-)
PW
Paul Webster
Re: LTK copy refactoring [message #334937 is a reply to message #334932] Tue, 10 March 2009 14:16 Go to previous messageGo to next message
Hi Paul,
Can you provide any hints on where I might start to add copy refactoring,
both for Project Explorer and what parts of the refactoring framework
would I need to invoke to notify the participants?
Also, I noticed in addition to copy refactoring participants there are
create refactoring participants.
org.eclipse.ltk.core.refactoring.createParticipants
How are these two intended to be used? For example, will copy refactoring
happen on a copy (CTRL+C) or would it happen on the paste (CTRL+V)?
If I can figure out how to patch support for this in I might, assuming I
can figure it out.
Dave
Re: LTK copy refactoring [message #335311 is a reply to message #334937] Tue, 31 March 2009 14:14 Go to previous message
I guess there's probably 2 parts to it.
1) you would have to modify the global actions, similar to how
org.eclipse.ui.actions.MoveResourceAction uses
org.eclipse.ui.internal.ide.actions.LTKLauncher.openMoveWiza rd(IStructuredSelection)
That makes the LTK available to the Project Explorer and Resource
Navigator (deprecated in 3.5)
Then you need to add the wizard and associated supprt (Processing,
Refactoring, Change support, etc).
See org.eclipse.ltk.ui.refactoring.resource.MoveResourcesWizard and
org.eclipse.ltk.internal.core.refactoring.resource.MoveResou rcesProcessor
as starting points.
PW
Paul Webster
Previous Topic:dynamically updating plugin classpath
Next Topic:How to remove an Internal Discouraged Access Warnings for NewKeysPreferencePage?
Current Time: Tue Nov 25 00:40:19 EST 2025
Powered by FUDForum. Page generated in 0.05704 seconds
