Home » Eclipse Projects » Eclipse Platform » Huge memory consumption of Infocenter
Huge memory consumption of Infocenter [message #334916] Tue, 10 March 2009 04:24 Go to next message
I'm struggling with large memory consumption of Eclipse Infocenter. We
have a Infocenter library with 6 books, containing 12 000 pages
altogether. There are 4 million hits / 34 000 visits per month.
Allocated memory to eclipse is -vmargs -Xmx1536m (out of 4GB total in
server), but it is still running out of memory:
java.lang.OutOfMemoryError: Java heap space
Can it be true that standalone Infocenter really requires over 1536M
memory? Is there any recommended value?
For me it also seems that there might be some memory leak since the memory
consumption slightly grows until the maximum is reached (takes 24 hours or
so).
One thing that I found is setting locales (-nl en -locales en), but
testing didn't provide too convincing results.
I'd appreciate any help. Thanks!
Re: Huge memory consumption of Infocenter [message #334919 is a reply to message #334916] Tue, 10 March 2009 08:49 Go to previous messageGo to next message
Originally posted by: nospam_kowalskilee.gmail.com
There is an Eclipse newsgroup that focuses on questions about the help
system and Infocenter. It is the eclipse.platform.ua newsgroup.
I recommend that you repost your message to that newsgroup. The Eclipse
committers that cover the infocenter code follow that newsgroup and then
will see your posting there.
When you post your message to eclipse.platform.ua newsgroup, I suggest
that you also include what operating system (OS) you're running the
infocenter on, as well as what Eclipse Version you're using for the
infocenter.
Hope this helps,
Lee Anne
Niina Känsälä wrote:
> memory consumption slightly grows until the maximum is reached (takes 24
> hours or so).
Re: Huge memory consumption of Infocenter [message #334927 is a reply to message #334919] Tue, 10 March 2009 11:14 Go to previous message
Thanks a lot Lee Ann!
I did what you suggested
( http://www.eclipse.org/newsportal/article.php?id=906&gro up=eclipse.platform.ua#906)
Previous Topic:Common Navigator ClassCastException
Next Topic:ResourceNavigator End of Life
Current Time: Thu Nov 13 16:47:07 EST 2025
Powered by FUDForum. Page generated in 0.03394 seconds
