Home » Eclipse Projects » Eclipse Platform » Common Navigator tutorial
Common Navigator tutorial [message #334868] Wed, 04 March 2009 17:36 Go to next message
I did the common navigator tutorial
http://rcpquickstart.com/2007/04/25/common-navigator-tutoria l-1-hello-world/
It work in Eclipse 3.3.
When I moved the code to Eclipse 3.5 I got the following Error
Cannot find navigator content extension (using triggerPoints) for object
"example.navigator.content.ParentBean@1400eb0" parent path:
"example.navigator.NavigatorRoot@3f0860".
Check that you have an expression for this object in a navigatorContent
triggerPoints or enablement.
What do I need to do to fix the problem.
Re: Common Navigator tutorial [message #334870 is a reply to message #334868] Wed, 04 March 2009 18:17 Go to previous message
You have hit an API compatibility introduced in 3.5M5, I'm just about to
commit the fix, so it shoudl be in tonight's nightly.
To fix it with your current build, make sure you have your ParentBean
object as an enablement or triggerPoint.
Francis
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:Plugin supplies global ant property, but build.xml doesn't see it
Next Topic:wizards
Current Time: Mon Nov 03 22:38:51 EST 2025
Powered by FUDForum. Page generated in 0.03031 seconds
