Home » Eclipse Projects » Eclipse Platform » [JFace] tristate tree viewer
[JFace] tristate tree viewer [message #334836] Mon, 02 March 2009 13:04 Go to next message
Originally posted by: alamothe.ptt.yu
I'm unsuccessfully trying to get a tristate behaviour in CheckboxTreeViewer,
that is an item can be checked, grayed or unchecked. Is this the limitation
of JFace, SWT Tree control or I'm doing something wrong??
Re: [JFace] tristate tree viewer [message #334840 is a reply to message #334836] Mon, 02 March 2009 13:26 Go to previous messageGo to next message
It appears to be a limitation of SWT...
Nikola Mihajlovic wrote:
> CheckboxTreeViewer, that is an item can be checked, grayed or
> unchecked. Is this the limitation of JFace, SWT Tree control or I'm
Re: [JFace] tristate tree viewer [message #334841 is a reply to message #334840] Mon, 02 March 2009 14:11 Go to previous messageGo to next message
--------------050407000607050803020700
Use "checkboxTreeViewer.setChecked()" and
"checkboxTreeViewer.setGrayChecked()". This will give you the tristate
behavior.
Mircea
<html>
<head>
</head>
behavior. <br>
&nbsp;<br>
Mircea<br>
<br>
<blockquote cite="midgoh8bt$eht$1@build.eclipse.org" type="cite">
<pre wrap="">It appears to be a limitation of SWT...
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050407000607050803020700--
Re: [JFace] tristate tree viewer [message #334843 is a reply to message #334841] Mon, 02 March 2009 17:59 Go to previous messageGo to next message
While I can programatically set one of the three states, a user cannot cycle
between three states with a mouse click, but only between two. Since it's a
problem with SWT, I've posted this on their newsgroup (the same problem
exists with a regular checkbox, that is not inside the Tree)
> behavior.
> Mircea
>>> Hi,
Re: [JFace] tristate tree viewer [message #334849 is a reply to message #334843] Tue, 03 March 2009 06:28 Go to previous messageGo to next message
It should be possible to work around this.I thought I'll share this - hope
it helps.
It is possible to add a ICheckStateListener and manipulate the state, for
example :
chkBoxViewer.addCheckStateListener(new ICheckStateListener(){
public void checkStateChanged(CheckStateChangedEvent event) {
MyModel item=(MyModel) event.getElement();
switch (item.state) {
case 0:{
chkBoxViewer.setGrayChecked(item, true);
break;
case 1:{
chkBoxViewer.setGrayed(item, false);
chkBoxViewer.setChecked(item, true);
break;
case 2:{
chkBoxViewer.setGrayChecked(item, false);
break;
item.state=++item.state%3;
Hitesh
>> behavior.
>> Mircea
>>>> Hi,
Re: [JFace] tristate tree viewer [message #334850 is a reply to message #334849] Tue, 03 March 2009 08:13 Go to previous message
Thanks! It's exactly how I solved this problem :-)
> hope it helps.
> for example :
> case 0:{
> break;
> case 1:{
> break;
> case 2:{
> break;
> Hitesh
>> cannot cycle between three states with a mouse click, but only
>> between two. Since it's a problem with SWT, I've posted this on
>> their newsgroup (the same problem exists with a regular checkbox,
>>> tristate behavior.
>>> Mircea
>>>>> Hi,
Previous Topic:unasked for breakpoint
Next Topic:Ganymede SR2 update updates eclipse.ini !
Current Time: Tue Jul 15 17:00:31 EDT 2025
Powered by FUDForum. Page generated in 0.05950 seconds
