Home » Archived » XML Schema Definition (XSD) » Trying to create an XSD annotation element
Trying to create an XSD annotation element [message #33959] Thu, 11 December 2003 12:57 Go to next message
I am trying to build some app info for an annotation element which I'll
then add to an XSDElementDeclaration.
My code is as follows:
XSDAnnotation xsdAnnotation = fXsdFactory.createXSDAnnotation();
xsdElementDeclaration.setAnnotation(xsdAnnotation);
Element applicationInformation =
xsdAnnotation.createApplicationInformation(sourceURI);
My question is , is what do I pass as the sourceURI for the
createApplicationInformation method?
Hayden
Re: Trying to create an XSD annotation element [message #34043 is a reply to message #33959] Thu, 11 December 2003 14:09 Go to previous message
Hayden,
The source attribute on <appinfo> and <documentation> is optional, so you
may choose to pass null. It's a good idea for <appinfo> to identify the
"app" so that when you are looking for your appinfo you can tell it apart
from appinfo that isn't yours.
> Hayden
Re: Trying to create an XSD annotation element [message #581443 is a reply to message #33959] Thu, 11 December 2003 14:09 Go to previous message
Hayden,
> Hayden
Previous Topic:Trying to create an XSD annotation element
Next Topic:Headless xsd2genmodel ?
Current Time: Fri Nov 07 07:02:31 EST 2025
Powered by FUDForum. Page generated in 0.22716 seconds
