Home » Archived » BIRT » Wrong results in crosstab
| Wrong results in crosstab [message #334797] |
Mon, 28 January 2008 08:43  |
Hi people,
I have a crosstab that shows some summarized fields, (A, B, C), when I
preview the results (at preview's tab), all goes fine, but viewing the
results in xls or web viewer, it results in strange data. The C field
shows strange numbers, very very big numbers. I have tried with a new
report file, but happens the same problem.
Any ideas?
Hans.
| Re: Wrong results in crosstab [message #340886 is a reply to message #334797] |
Mon, 28 January 2008 08:51   |
I forgot to add that I have two crosstabs. The problem happens sometimes
in first crosstab and other times it happens in the second crosstab
Hans escribió:
> Hi people,
> I preview the results (at preview's tab), all goes fine, but viewing the
> Any ideas?
> Hans.
| Re: Wrong results in crosstab [message #340887 is a reply to message #334797] |
Mon, 28 January 2008 09:00   |
Originally posted by: tigeleo.yahoo.com
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
May be you display rowid or time in milliseconds
| Re: Wrong results in crosstab [message #340961 is a reply to message #334797] |
Hans escribió:
> Hi people,
> Any ideas?
> Hans.
| Re: Wrong results in crosstab [message #340962 is a reply to message #334797] |
Hans ?????:
> Hi people,
> Any ideas?
> Hans.
| Re: Wrong results in crosstab [message #346523 is a reply to message #340887] |
Mon, 28 January 2008 09:19   |
Nope, and after a many crazy things, I can fix the problem. The solution
was to change all the report parameters to String. I've never had this
problem with crosstabs, indeed, I've worked with a template with the
same report parameters and same crosstabs, it's the first time that I
see this strange behaviour. Could be a bug?
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> when I preview the results (at preview's tab), all goes fine, but
>> viewing the results in xls or web viewer, it results in strange data.
>> The C field shows strange numbers, very very big numbers. I have tried
>> with a new report file, but happens the same problem.
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #346598 is a reply to message #340962] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #346673 is a reply to message #340962] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #350816 is a reply to message #340887] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #350891 is a reply to message #340887] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #350966 is a reply to message #340962] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
| Re: Wrong results in crosstab [message #351042 is a reply to message #340962] |
Hans.
tigeleo escribió:
> Hans ?????:
>> Hi people,
>> Any ideas?
>> Thanks,
>> Hans.
Current Time: Sat Nov 08 15:41:25 EST 2025
Powered by FUDForum. Page generated in 0.06401 seconds
