Home » Eclipse Projects » Eclipse Platform » Get extension point from plugin..
Get extension point from plugin.. [message #334777] Fri, 27 February 2009 04:39 Go to next message
I have a problem getting information from an plugin.xml .
Following situation:
I have an plugin A in which depends on an other plugin B.
Now I want to get from plugin A some information of this extension point
of plugin B:
<extension point="org.eclipse.team.core.fileTypes">
<?gmfgen generated="true"?>
<fileTypes
type="text"
extension="dm">
</fileTypes>
</extension>
So what I want is to get in plugin A the file type defined in an extension
poit of (see above) in plugin B
Thanks for your help!
Best regards
Alex
Re: Get extension point from plugin.. [message #334786 is a reply to message #334777] Fri, 27 February 2009 09:28 Go to previous messageGo to next message
There are extensions and extension points. One plugin defines an
extension point (like org.eclipse.ui defines org.eclipse.ui.commands).
All the other plugins contribute extensions to that extension point.
It seems that your plugin B is contributing an extension, and you would
like to read that in plugin A? If that is the case, all you need to do
is get the IExtensionRegistry and track down the IExtension from plugin B.
Check out the API (java docs) for those 2 classes.
PW
Paul Webster
Re: Get extension point from plugin.. [message #334881 is a reply to message #334786] Fri, 06 March 2009 05:40 Go to previous messageGo to next message
first thanks for your reply.
Now I can get the IExtensionPoint:
<fileTypes
type="text"
extension="dm">
</fileTypes>
</extension>
By:
Platform.getExtensionRegistry().getExtensionPoint("org.eclipse.team.core.fileTypes ");
But how can I now get that attribute: extension="dm" ?
Thanks for your help.
Best regards
Alex
Re: Get extension point from plugin.. [message #334882 is a reply to message #334881] Fri, 06 March 2009 05:48 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
Hello Alexander,
You'd rather try to use
Platform.getExtensionRegistry().getConfigurationElementsFor( "org.eclipse.team.core.fileTypes")
that returns you some IConfigurationElement s (see javadoc) which
contains everything you'll need to know about the extensions of
"org.eclipse.team.core.fileTypes".
Hope that helps
Mickael
Alexander Mack a écrit :
> Hello,
> <fileTypes
> type="text"
> extension="dm">
> </fileTypes>
> </extension>
> By:
> Best regards
> Alex
Re: Get extension point from plugin.. [message #334884 is a reply to message #334882] Fri, 06 March 2009 07:07 Go to previous message
Okay, I knew about the method getConfigurationElementsFor("..")
The problem is that I get an Array with about 300 entries.
So I tried to reduce it by giving the namespace but then my array has 0
entries.
But I am not really sure what the namespace of that plugin is.
Could you pleas give me an example?
Great thanks for your help
Alex
Previous Topic:Activator.stop() is not called at shutdown of OS (Windows XP)
Next Topic:Shared eclipse settings for a team
Current Time: Wed Nov 05 13:04:40 EST 2025
Powered by FUDForum. Page generated in 0.04907 seconds
