| Loading xml files from jars at the runtime [message #334750] |
Thu, 26 February 2009 00:24  |
I want to know if there is any mechanism by which i can load a xml file
,which is inside a jar,at the runtime.
Also my requirement is ,i dont know the name of the jars which contain xml
files,as it gets resolved at the runtime and want all the jars in the path
(known external directory)to be picked at runtime.
Is there any way to do this?
-sheela
| Re: Loading xml files from jars at the runtime [message #334765 is a reply to message #334750] |
Thu, 26 February 2009 09:55  |
Typically you'd know what class it was stored relative to and you'd use
java.lang.Class.getResourceAsStream. ClassLoader has similar methods...
Sheela wrote:
> file ,which is inside a jar,at the runtime.
> xml files,as it gets resolved at the runtime and want all the jars in
> the path
> -sheela
FUDForum. Page generated in 0.04247 seconds
