Home » Eclipse Projects » Eclipse Platform » [Databinding] Problem with listener of AggregateValidationStatus
[Databinding] Problem with listener of AggregateValidationStatus [message #334738] Wed, 25 February 2009 13:14 Go to next message
I have a form with 6 fields that are bound using DataBindingContext. I
have a AggregateValidationStatus for the bindings with strategy as
MAX_SEVERITY. A listener has been attached to the
AggregateValidationStatus as below:-
IObservableValue status = new
AggregateValidationStatus(dataBindingContext.getBindings(),
AggregateValidationStatus.MAX_SEVERITY);
status.addValueChangeListener(new IValueChangeListener() {
public void handleValueChange(ValueChangeEvent event) {
// do something
When any of the text fields is modified, I need a callback to
handleValueChange method. Any thoughts?
I read through an earlier discussion. The solution suggested is to use
getValue() on the AggregateValidationStatus inside the listener. How do I
get a call to the listener everytime the text is modified?
http://dev.eclipse.org/newslists/news.eclipse.platform/msg80 116.html
Ravi
Re: [Databinding] Problem with listener of AggregateValidationStatus [message #334742 is a reply to message #334738] Wed, 25 February 2009 14:28 Go to previous messageGo to next message
Your AggregateValidationStatus will not necessarily change every time
one of the text fields is updated, since intermediate values may have
the same validation status (IStatus.OK) and in these situations no
change event would be fired.
You need to add listeners directly on your target IObservableValues
rather than on an AggregateValidationStatus.
Matthew
Ravi wrote:
> status.addValueChangeListener(new IValueChangeListener() { public void
> // do something
> I get a call to the listener everytime the text is modified?
> Ravi
Re: [Databinding] Problem with listener of AggregateValidationStatus [message #334772 is a reply to message #334742] Thu, 26 February 2009 12:56 Go to previous message
Thanks for the quick response, Matthew.
To capture the event, I am adding the listeners on the target observable.
Ravi
> Matthew
> Ravi wrote:
>> // do something
>> Thanks,
>> Ravi
Previous Topic:[DataBinding] Best pratice to observe instance model (Bean, EMF..) which change
Next Topic:retrieving local history of an IFile
Current Time: Thu Jul 17 19:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.25433 seconds
