Home » Eclipse Projects » Eclipse Platform » How to create own Markers by double click on the vertical ruler
How to create own Markers by double click on the vertical ruler [message #334700] Wed, 25 February 2009 05:52 Go to next message
I'm working on a project, where new markers need to be used. I have
defined the new marker type and also annotation type in the plugin.xml
file and I can see it now in the Preferences.
But I want to create new markers by double-click on the vertical ruler.
The editor, that is to be used is the CEditor from the Eclipse for C/C++
developers. Now when I double click on the vertical ruler, new breakpoint
is created (as usual).
I want to ask how can I create my own markers by double click. Should I
search some extension points in the CEditor's plugin.xml or can I make
this by programming.
Thanks in advance.
Martin
Re: How to create own Markers by double click on the vertical ruler [message #334712 is a reply to message #334700] Wed, 25 February 2009 08:28 Go to previous messageGo to next message
> ruler. The editor, that is to be used is the CEditor from the Eclipse
> for C/C++ developers. Now when I double click on the vertical ruler,
> new breakpoint is created (as usual). I want to ask how can I create
You can't. There is only one double-click action and obviously the
CEditor already defines it.
Dani
> Should I search some extension points in the CEditor's plugin.xml or
> can I make this by programming.
> Thanks in advance.
> Martin
Re: How to create own Markers by double click on the vertical ruler [message #334720 is a reply to message #334712] Wed, 25 February 2009 09:09 Go to previous messageGo to next message
Hi Dani,
thanks for the answer.
But what if I overwrite this double-click action?
Martin
How to set my plug-in on top of the prerequisite tree ???? [message #334867 is a reply to message #334700] Wed, 04 March 2009 16:50 Go to previous messageGo to next message
I want to create my markers per double-click in the vertical ruler.
After some research and developmen, I found that the editorActions
extension point can be used to overwrite the RulerDoubleClick Action.
RulerDoubleClick is actually an actionID attribute in a Action
definitions. My definition looks like:
<extension
point="org.eclipse.ui.editorActions">
<editorContribution
targetID="org.eclipse.cdt.ui.editor.CEditor"
id="org.eclipse.cdt.debug.ui.CEditor.MyRulerActions">
<action
label="%Dummy.label"
class=" xx.xxx.xxxxxxx.xxxxx.ui.actions.CreateMyMarkerActionDelegate "
actionID="RulerDoubleClick"
id="xx.xx.xxxxxxx.xxxxx.ui.actions.CreateMyMarkerAction">
</action>
</editorContribution>
The org.eclipse.cdt.ui plugin has a similar declaration, but there the
defined action is for creating Bookmarks. The org.eclipse.cdt.degbu.ui
overwrites the RulerDoubleClick actionId and set it to be used for
creating breakpoints.
With my declaration I made it one time. I could create my markers per
double click, but next time I couldn't.
So I found this in the extension point help: "
actionID - Internal tag for use by the text editors. Should not be used by
plug-in developers. The following IDs have special meaning for the text
editor framework:
"RulerClick": the contributed action which is invoked upon single-click in
the (left) vertical ruler
"RulerDoubleClick": the contributed action which is invoked upon
single-click in the (left) vertical ruler
If multiple extensions contribute ruler actions to the same text editor,
the extension whose plug-in is at the top of the prerequisite tree wins.
If there are multiple such plug-ins, the first wins. "
According to it, it my help. So my question is, how can I set my plug-in
to be on the top of the prerequisite tree ???
Thanks in advance.
Martin
Re: How to set my plug-in on top of the prerequisite tree ???? [message #334977 is a reply to message #334867] Fri, 13 March 2009 05:12 Go to previous message
Martin P wrote:
> Hello,
> <extension
> <editorContribution
> <action
> </action>
> double click, but next time I couldn't. So I found this in the
> used by plug-in developers. The following IDs have special meaning for
> the text editor framework: "RulerClick": the contributed action which
> is invoked upon single-click in the (left) vertical ruler
> single-click in the (left) vertical ruler If multiple extensions
> contribute ruler actions to the same text editor, the extension whose
> plug-in is at the top of the prerequisite tree wins. If there are
> plug-in to be on the top of the prerequisite tree ???
Your plug-in must declare to require the other ones (in manifest.mf).
Dani
> Thanks in advance.
> Cheers,
> Martin
Previous Topic:Problems View - custom attribute column
Next Topic:working sets in "Project References"
Current Time: Mon Jul 21 22:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.04553 seconds
