Home » Eclipse Projects » Eclipse Platform » How to create different CellEditors per row?
How to create different CellEditors per row? [message #334647] Mon, 23 February 2009 04:17 Go to next message
Originally posted by: TheRealHawk.Freenet.de
in my project I need to edit a lot of different objects - so I need to
implement a dialog for each object.
Because theere are a lot of properties on each object it takes some time to
create such a dialog.
So my idea was to implement a simple-dialog, which only shows a table and a
property and ints value per row.
--> This is no problem.
My problem is: How can I set different CellEditors for each value-column?
Currently I use a TableViewer and TableViewerColumns together with an
EdititingSupport for each column.
Markus
Re: How to create different CellEditors per row? [message #334649 is a reply to message #334647] Mon, 23 February 2009 05:23 Go to previous messageGo to next message
You simply need to make your EditingSupport return the appropriate
CellEditor or do I miss the point?
Tom
Markus Koch schrieb:
> Markus
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to create different CellEditors per row? [message #334650 is a reply to message #334649] Mon, 23 February 2009 09:05 Go to previous messageGo to next message
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:gnttff$24f$1@build.eclipse.org...
> Tom
>> to
>> a
>> Markus
Yeah - thats it. :-)
Now I have another question: are there some default jface-classes for java
Beans?
e.g. ICellModifier or EdititingSupport or ITableLableProvider?
Of course I can implement them - but maybe there are some ready classes
that I can use?
Re: How to create different CellEditors per row? [message #334651 is a reply to message #334650] Mon, 23 February 2009 09:11 Go to previous messageGo to next message
> Beans?
> that I can use?
No we don't have such stuff but you could take a look at
JFace-Databinding which I'd suggest to use. It provides specialized
LabelProviders for observed attributes of a bean and integration into
EditingSupport.
http://wiki.eclipse.org/JFace_Data_Binding/Snippets
Tom
Re: How to create different CellEditors per row? [message #334652 is a reply to message #334651] Mon, 23 February 2009 09:49 Go to previous message
news:gnuar2$pm9$1@build.eclipse.org...
>> java
>> Beans?
>> that I can use?
> EditingSupport.
> Tom
Thank you very much for the link - the examples are exactly what I'm looking
for.
Markus
Previous Topic:How to create a plug-in that uses reflection to find files with annotations ?
Next Topic:How does eclipse handle linked java files in an Ant build file?
Current Time: Sat Aug 23 05:46:36 EDT 2025
Powered by FUDForum. Page generated in 0.07098 seconds
