Home » Eclipse Projects » Eclipse Platform » [Databinding] Problem with AggregateValidationStatus
[Databinding] Problem with AggregateValidationStatus [message #334622] Fri, 20 February 2009 10:36 Go to next message
Hello.
I am using a DataBindingContext where three Text's are bound to EMF
models by
bindingContext.bindValue(SWTObservables.observeText(text, SWT.Modify),
EMFObservables.observeValue(eObject, eStructuralFeature), new
UpdateValueStrategy(UpdateValueStrategy.POLICY_CONVERT).setA fterConvertValidator(validator),
new UpdateValueStrategy(UpdateValueStrategy.POLICY_NEVER));
Those validator's are called correctly. Whenever I type something into
one of the text fields the validate method is called.
I further added an AggregateValidationStatus by
AggregateValidationStatus aggregateValidationStatus = new
AggregateValidationStatus(bindingContext,
AggregateValidationStatus.MAX_SEVERITY);
and added an IChangeListener.
The problem is that the handleChange method of that listener is only
called once (the first time I type something into one of those text
fields), but not later on anymore.
I would have exspected that the handleChange method is called as often
as one of the validators validate method is called.
How does the AggregateValidationStatus class work?
That leads me to my next question? I want to listen to whenever a
validate method of the above added validator's was called. I need it to
setPageComplete of a WizardPage (as all text fields together have an
influence on that).
Kai
Re: [Databinding] Problem with AggregateValidationStatus [message #334628 is a reply to message #334622] Fri, 20 February 2009 11:09 Go to previous messageGo to next message
My guess is that because you are using MAX_SEVERITY you might not be
editing the field that has the current max severity, (i.e. you are
editing a field with a lower severity validation status.
> influence on that).
Have you tried WizardPageSupport.create(DataBindingContext, WizardPage)?
Matthew
Re: [Databinding] Problem with AggregateValidationStatus [message #334630 is a reply to message #334628] Fri, 20 February 2009 12:46 Go to previous messageGo to next message
Comments below.
It doesn't work whatever text field I edit. handleChange is called once
and after that not anymore.
And even when using MERGED I get the same behavior.
What do I have to do that handleChange method is called everytime the
text field is modified?
>> to setPageComplete of a WizardPage (as all text fields together have
>> an influence on that).
Sounds ok, but it does also some things I don't like (updates the error
message). Also there are several other cases I need the
AggregateValidationStatus to work.
Any suggestions?
By the way I am using Eclipse 3.5M5.
Kai
Re: [Databinding] Problem with AggregateValidationStatus [message #334632 is a reply to message #334630] Fri, 20 February 2009 13:51 Go to previous messageGo to next message
Are you doing anything with the value of the AggregateValidationStatus?
in the change listener? AVS is backed by a ComputedValue which fires an
event once and doesn't fire any more until you look at the new value.
It's kind of like Schroedinger's cat--you don't get any more change
events until you look in the safe. See
ObservableTracker.getterCalled(IObservable). Then see IObservableValue
and look for methods tagged @TrackedGetter.
We do this to avoid an event storm if several observables are changed
rapidly. I think it will fix your problem just to call getValue() on
the AVS inside the change listener.
Matthew
Kai Schlamp wrote:
> Comments below.
> Any suggestions?
> Kai
Re: [Databinding] Problem with AggregateValidationStatus [message #334634 is a reply to message #334632] Fri, 20 February 2009 14:27 Go to previous messageGo to next message
So, Schroedinger's cat ... nice analogy ... I hope my
AggregateValidationStatus doesn't contain any transitional states ;-)
And yes, it works now when calling getValue inside the change listener.
Is there an easy way to get the AggregateValidationStatus from within
the change listener? A "(AggregateValidationStatus) event.getSource())"
results in a ClassCastException (java.lang.ClassCastException:
org.eclipse.core.databinding.AggregateValidationStatus$1 cannot be
cast to org.eclipse.core.databinding.AggregateValidationStatus).
Do I really have to pass the AggregateValidationStatus to the change
listener myself?
Thank you,
Kai
Re: [Databinding] Problem with AggregateValidationStatus [message #334636 is a reply to message #334634] Fri, 20 February 2009 16:39 Go to previous message
Try using an IValueChangeListener instead of IChangeListener:
aggregateValidationStatus.addValueChangeListener(
new IValueChangeListener() {
public void handleValueChange(ValueChangeEvent event) {
event.getObservableValue().getValue();
Matthew
> listener myself?
> Thank you,
> Kai
>> AggregateValidationStatus? in the change listener? AVS is backed by a
>> ComputedValue which fires an event once and doesn't fire any more
>> until you look at the new value. It's kind of like Schroedinger's
>> cat--you don't get any more change events until you look in the safe.
>> See ObservableTracker.getterCalled(IObservable). Then see
>> IObservableValue and look for methods tagged @TrackedGetter.
Previous Topic:Radio tool item with pulldown menu
Next Topic:SelectionProvider is not set in the WindowSelectionService
Current Time: Wed Jul 23 01:19:06 EDT 2025
Powered by FUDForum. Page generated in 0.04953 seconds
