Home » Eclipse Projects » Eclipse Platform » SelectionProvider is not set in the WindowSelectionService
SelectionProvider is not set in the WindowSelectionService [message #334587] Thu, 19 February 2009 04:45 Go to next message
I'm designing a RCP application with views and editor parts. In some part,
i'm using the SelectionService mechanism and i set SelectionProvider
object on their site "getSite().setSelectionProvider(provider)".
In a other hand, i'm using the "org.eclipse.ui.menus" to display popup
menu with command. Each command refered to a
"org.eclipse.core.expressions.definitions" extension point to test if we
display the command or not. I use the expression "selection" and it seems
to do not work correctly. At the initialization of the RCP, the
"selection" is not updated and the item associated to the command is not
displayed in the popup menu.
I need to re-activate the part to make it work. I've seen that there are
two SelectionService which are declared at the beginning :
PageSelectionService and WindowSelectionService. The
WindowSelectionService does not call its setActivePart() method at the
initialization of the application so the provider is not set for this
service. So the selection is not updated for the
"org.eclipse.core.expressions.definitions" extension point. And i think
it's the reason why it is not working properly but i might be wrong.
If someone knows a way to make it work correctly without reactivating the
part everytime we have to launch the application, i would appreciate it.
Thanks.
Re: SelectionProvider is not set in the WindowSelectionService [message #334588 is a reply to message #334587] Thu, 19 February 2009 05:09 Go to previous messageGo to next message
a) Check that you implemented the setFocus() method appropriately
b) Wouldn't it be better if the Popup-Menu and its commands use the
selection from use the activeMenuSelection
Tom
Maghen Calinghee schrieb:
> part, i'm using the SelectionService mechanism and i set
> SelectionProvider object on their site
> seems to do not work correctly. At the initialization of the RCP, the
> displayed in the popup menu. I need to re-activate the part to make it
> work. I've seen that there are two SelectionService which are declared
> at the beginning : PageSelectionService and WindowSelectionService. The
> the part everytime we have to launch the application, i would appreciate
> it.
> Thanks.
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: SelectionProvider is not set in the WindowSelectionService [message #334613 is a reply to message #334588] Fri, 20 February 2009 09:40 Go to previous messageGo to next message
a) I've implemented correctly the setFocus() method.
b) I don't understand how to use the "activeMenuSelection" variable. I am
using the "selection" variable in the
"org.eclipse.expressions.definitions" extension point to know if the
selection is valid but the selection is not updated.
Re: SelectionProvider is not set in the WindowSelectionService [message #334614 is a reply to message #334588] Fri, 20 February 2009 09:44 Go to previous messageGo to next message
Hi Tom,
Thanks you for replying.
a) I've implemented correctly the setFocus() method correctly
whereas I need to use the "selection" variable to check if the selection
is valid to display the Popup-Menu.
Maghen.
Re: SelectionProvider is not set in the WindowSelectionService [message #334626 is a reply to message #334614] Fri, 20 February 2009 11:05 Go to previous messageGo to next message
"selection" is the global eclipse selection, usually based on the active
part.
activeMenuSelection is the selection that is available during a context
(popup) menu. It is not necessarily the same as the "selection"
variable, since it comes from the selection provider set in
getSite().registerContextMenu(*)
PW
Paul Webster
Re: SelectionProvider is not set in the WindowSelectionService [message #334637 is a reply to message #334626] Sat, 21 February 2009 03:53 Go to previous message
I've used the "activeMenuSelection" and it works well, thanks you Paul and
Tom. But i'm trying to understand how the "selection" works. I have a view
with a viewer which contributes to the selection service as selection
provider. And i have created another view which listens to this provider.
I would like to display in this view the same menu items which appear in
the pop up menu of the first view when i do a selection in that part. I
would to use the extension point "org.eclipse.expressions.definitions"
where i defined the rules which allow to display the menu item or not. But
this time, i use the "selection" variable to know the selection in the
first view. And it does not work properly, i need to re-activate the first
view to make it work correctly. I'm wondering how can i do this correctly.
Moreover i use in the first view a "dynamic selection provider" because i
have several viewers. But i don't think it is linked to my problem.
Maghen.
Previous Topic:[Databinding] Problem with AggregateValidationStatus
Next Topic:Get InputStream for resource defined in extension point.
Current Time: Sat Aug 23 05:44:02 EDT 2025
Powered by FUDForum. Page generated in 0.03727 seconds
