| getService() without the UI?! [message #334572] |
Wed, 18 February 2009 10:40  |
currently I'm using PlatformUI.getWorkbench().getService() a lot, using
the extensionpoint "org.eclipse.ui.services".
In general its working fine. But it suffers a bit from its bondage to the
UI. Why is something so general like a servicelocator bound to the UI
anyway? Every Plugin I create that uses this servicelocator has to have
"org.eclipse.ui" as a dependency. Even if it is a model plugin (EMF) thats
only dependencie to the UI would be the servicelocator.
Would'nt it be nice to have a UI-less servicelocator?
Aspecially since currently it is not possible to use services as long the
workbench has not been started. Likewise when opening a login dialog
within Application.start() and the connection to a database is controlled
by a ConnectionService... :)
Jan Kohnert
| Re: getService() without the UI?! [message #334590 is a reply to message #334589] |
Thu, 19 February 2009 05:58  |
* org.eclipse.emf.example.library.service.xmi.test1 declares a service
* org.eclipse.emf.example.library.service.teneo.derby.test1 declares a
service
* org.eclipse.emf.examples.library.databinding consumes them
(See the Activator)
Tom
Jan Kohnert schrieb:
> Tom,
> which of your chared plugins contains the declarative service example?
> Jan
> Tom Schindl wrote:
>> If you want to do things at the lower level I'd suggest to use OSGi
>> Declarative Services.
>> If you need an example how to e.g. expose a EMF-Model as a Declarative
>> Service you can take a look the example application [1] I'm writing for
>> my EclipseCon [2] talk.
>> Tom
>> [1] http://github.com/tomsontom/emf-databinding-example/tree/mas ter
>> [2]Mixing Eclipse Technologies to create Enterprise Ready
>> Database-RCP-Frontends - http://www.eclipsecon.org/2009/sessions?id=446
>>> Hello,
>>> In general itᅵs working fine. But it suffers a bit from its bondage to
>>> the UI. Why is something so general like a servicelocator bound to the
>>> UI anyway? Every Plugin I create that uses this servicelocator has to
>>> have "org.eclipse.ui" as a dependency. Even if it is a model plugin
>>> (EMF) thats only dependencie to the UI would be the servicelocator.
>>> the workbench has not been started. Likewise when opening a login dialog
>>> controlled by a ConnectionService... :)
>>> Jan Kohnert
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
FUDForum. Page generated in 0.04913 seconds
