Home » Eclipse Projects » Eclipse Platform » getService() without the UI?!
getService() without the UI?! [message #334572] Wed, 18 February 2009 10:40 Go to next message
currently I'm using PlatformUI.getWorkbench().getService() a lot, using
the extensionpoint "org.eclipse.ui.services".
In general it’s working fine. But it suffers a bit from its bondage to the
UI. Why is something so general like a servicelocator bound to the UI
anyway? Every Plugin I create that uses this servicelocator has to have
"org.eclipse.ui" as a dependency. Even if it is a model plugin (EMF) thats
only dependencie to the UI would be the servicelocator.
Would'nt it be nice to have a UI-less servicelocator?
Aspecially since currently it is not possible to use services as long the
workbench has not been started. Likewise when opening a login dialog
within Application.start() and the connection to a database is controlled
by a ConnectionService... :)
Jan Kohnert
Re: getService() without the UI?! [message #334575 is a reply to message #334572] Wed, 18 February 2009 11:38 Go to previous messageGo to next message
If you want to do things at the lower level I'd suggest to use OSGi
Declarative Services.
If you need an example how to e.g. expose a EMF-Model as a Declarative
Service you can take a look the example application [1] I'm writing for
my EclipseCon [2] talk.
Tom
[1] http://github.com/tomsontom/emf-databinding-example/tree/mas ter
[2]Mixing Eclipse Technologies to create Enterprise Ready
Database-RCP-Frontends - http://www.eclipsecon.org/2009/sessions?id=446
Jan Kohnert schrieb:
> Hello,
> In general it�s working fine. But it suffers a bit from its bondage to
> the UI. Why is something so general like a servicelocator bound to the
> UI anyway? Every Plugin I create that uses this servicelocator has to
> have "org.eclipse.ui" as a dependency. Even if it is a model plugin
> (EMF) thats only dependencie to the UI would be the servicelocator.
> the workbench has not been started. Likewise when opening a login dialog
> controlled by a ConnectionService... :)
> Jan Kohnert
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: getService() without the UI?! [message #334578 is a reply to message #334572] Wed, 18 February 2009 13:34 Go to previous messageGo to next message
Jan
I use the Apache Commons Discover component that leverages the Java SPI
specification fairly successfully.
Karl
Jan Kohnert wrote:
> Hello,
> Jan Kohnert
Re: getService() without the UI?! [message #334589 is a reply to message #334575] Thu, 19 February 2009 05:18 Go to previous messageGo to next message
Tom,
which of your chared plugins contains the declarative service example?
Jan
Tom Schindl wrote:
> Tom
>> Hello,
>> In general itᅵs working fine. But it suffers a bit from its bondage to
>> Jan Kohnert
Re: getService() without the UI?! [message #334590 is a reply to message #334589] Thu, 19 February 2009 05:58 Go to previous message
* org.eclipse.emf.example.library.service.xmi.test1 declares a service
* org.eclipse.emf.example.library.service.teneo.derby.test1 declares a
service
* org.eclipse.emf.examples.library.databinding consumes them
(See the Activator)
Tom
> Tom,
> Jan
> Tom Schindl wrote:
>> Tom
>>> Hello,
>>> Jan Kohnert
Previous Topic:Creating a NonExistingFileEditorInput with content?
Next Topic:Load my plugin at startup in particular order
Current Time: Sat Aug 23 03:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.04462 seconds
