| 3.5M5 [viewContribution] action activation by the object selection doesn't work [message #334556] |
Tue, 17 February 2009 15:12  |
I'd like to have my own action in the debug view. The action has to be
activated when an element of the java stack frame is selected.
I defined the following extension point and created the class
my.test.DebugAction implements IViewActionDelegate.
<extension
point="org.eclipse.ui.viewActions">
<viewContribution
id="my.test.viewDebugContribution"
targetID="org.eclipse.debug.ui.DebugView">
<action
class="my.test.DebugAction"
id="my.test.DebugAction"
label="Test Action"
toolbarPath="additions">
enablesFor="+"
<selection
class="org.eclipse.jdt.debug.core.IJavaStackFrame">
</selection>
</action>
</viewContribution>
</extension>
This solution works fine for eclipse 3.4 (ganymede) but doesn't work for
3.5M5 (galileo) any more. The action is visible in the debug view but
disabled. If I remove the enablesFor="+" parameter then the action is
always enabled.
What is wrong in my extension point implementation or may be is it an
eclipse bug?
FUDForum. Page generated in 0.06616 seconds
