Updating a feature from a local update site with command line Update Manager (no internet connection [message #334551] |
Tue, 17 February 2009 07:34  |
Hello!
I am trying to update a feature from a local update site (I unzipped a
previously downloaded site) using headless Update Manger (I am using
Eclipse 3.2.2 and am not able to change that right now).
I installed a feature in headless mode from locally created update site
with:
java -cp startup.jar org.eclipse.core.launcher.Main -application
org.eclipse.update.core.standaloneUpdate -command install -from
file:///c:/UPSITE/myfeature_7.0.1.D071219 -featureId
com.myfeature.feature -version 7.0.1.D071219
Now, when I like to use the update command of headless update manager I
run into error. I unzip the new version of the feature to the previously
used local directory and run update (note that I do not have an Internet
connection)
org.eclipse.update.core.standaloneUpdate -command update -featureId
com.myfeature.feature -version 7.0.1.D080604
Then it results in the following error:
Connection failed.
Command failed.
Is such a scenario doable with update manager? Does it require an
Internet connection for updating properly or is it a bug?
Would really appreciate your help,
Blazej Kroll
FUDForum. Page generated in 0.03103 seconds
