Home » Eclipse Projects » Eclipse Platform » Load my plugin at startup in particular order
Load my plugin at startup in particular order [message #334525] Sun, 15 February 2009 23:55 Go to next message
Hi all,
I have written my own plugin to ask for some authentication required in
our case.
I wanted this plugin to run before any other plugin starts like CDT, JDT
etc.
When eclipse gets launched and is loading its other workbench plugins as
UI plugin, the same time I want it to start my plugin as well which is
supposed to be run as UI plugin.
I have used startup extension and implemented IStartup interface and
earlystartup() method of it. Though it runs when Eclipse gets launched but
I am facing following issues :-
1. It is started as one of the Worker thread, but I want it to be started
from UI thread i.e. (main / workebench) thread.
2. When Eclipse is launched with existing C/C++ projects in it, there is
no guarantee that my auth plugin gets loaded before CDT plugins. But I
want to assure that my plugin gets loaded first (though after core
platform plugins) and then CDT or other tool plugins. So, I want to ensure
this order.
3. I want this plugin to be launched always as part of UI thread.
Please help me out how can I achieve this ?
Thanks & Regards,
Re: Load my plugin at startup in particular order [message #334539 is a reply to message #334525] Mon, 16 February 2009 17:50 Go to previous messageGo to next message
On 2/15/2009 11:55 PM, Nayna wrote:
> Hi all,
> our case.
> etc.
> but I am facing following issues :-
> started from UI thread i.e. (main / workebench) thread.
> ensure this order.
First of all, you can use Display.asyncExec() to run a job on the UI thread.
Second, Eclipse does not allow for specifying particular ordering for
plugin activation. It is designed to be loosely coupled and
lazy-loading; ordering of plugins does not agree with those goals.
If you are building an RCP as opposed to just plugins that can be
installed into any Eclipse, there are some options to trigger
authentication at the "beginning," but it is not clear if that is what
you are doing.
Eric
Re: Load my plugin at startup in particular order [message #334565 is a reply to message #334525] Wed, 18 February 2009 06:21 Go to previous messageGo to next message
With 3.5 M5 you can set start levels.
see http://download.eclipse.org/eclipse/downloads/drops/S-3.5M5- 200902021535/eclipse-news-M5.html
May be it was available before and the enhancement for M5 provides only a GUI, I don't know.
Mariot
Nayna a écrit :
> Hi all,
> our case.
> etc.
> ensure this order.
> Thanks & Regards,
Re: Load my plugin at startup in particular order [message #334594 is a reply to message #334525] Thu, 19 February 2009 10:29 Go to previous message
You need to do some auth ... and interact with the user (as in request a
password) or simply do calculations? Are you an RCP app or a plugin?
For an RCP app that needs to do something (like check a license) you can
set the startlevel for that plugin to start before most of the workbench
(but after OSGi) and do your calculations. Split out the auth part from
the UI part, so the UI part happens later.
If you need to open some kind of login dialog (user/password) consider
doing it in the Splash screen ... there are already examples of this.
There's also the option of using http://eclipse-jaas.sourceforge.net/
which I believe performs some authentication and then can prevent
plugins from loading (or control them).
If you are simply an eclipse plugin that expects to run in the SDK (IDE)
then you are limited in what you can do.
For non-ui license checking, you might still be able to specify your
start level. You won't have access to the splash screen, and you would
have to check eclipse-jaas to see what it supports in an IDE environment
(where you don't control the application or product yourself).
org.eclipse.ui.startup will start your plugin in a non-UI thread after
the workbench has been initialized, so it's common to use an
asyncExec(*) or UIJob(preferred) to post your actions to the UI thread.
The startup will be in no particular order, and almost always after
many of the standard components (CDT, JDT) have started.
Later,
PW
Paul Webster
Previous Topic:getService() without the UI?!
Next Topic:Wrapping broken in ScrolledForm with GridLayout?
Current Time: Mon Nov 03 21:04:44 EST 2025
Powered by FUDForum. Page generated in 0.52022 seconds
