Home » Eclipse Projects » Eclipse Platform » List Open Files
List Open Files [message #334508] Fri, 13 February 2009 06:05 Go to next message
Is there an Eclipse platform API to list the currently open files in the
editor?
Ideally I'd like to be able to get all the open files of a particular type
(e.g. all open XML files) but I can only see a way to get the currently
active editor and which editor is associated with which file.
Re: List Open Files [message #334515 is a reply to message #334508] Fri, 13 February 2009 11:10 Go to previous messageGo to next message
> editor?
> type (e.g. all open XML files) but I can only see a way to get the
> currently active editor and which editor is associated with which file.
Here is one way that works with no context:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getEditorReferences()
It could be shorter if you have enough context to get the
IWorkbenchWindow or IWorkbenchPage directly.
Hope this helps,
Eric
Re: List Open Files [message #334531 is a reply to message #334515] Mon, 16 February 2009 08:37 Go to previous message
> Hope this helps,
> Eric
This works perfectly, thank you!
Previous Topic:How to change Console encoding?
Next Topic:Synchronizing open editors on the same file
Current Time: Sat Nov 08 00:25:39 EST 2025
Powered by FUDForum. Page generated in 0.02903 seconds
