Home » Eclipse Projects » Eclipse Platform » jface wizard translate ok/cancel/next/previous button
jface wizard translate ok/cancel/next/previous button [message #334476] Wed, 11 February 2009 16:33 Go to next message
Originally posted by: nospam.somewhere.org
I am using jface wizard and need to translate the default buttons:
How can I translate them to another language?
Re: jface wizard translate ok/cancel/next/previous button [message #334497 is a reply to message #334476] Thu, 12 February 2009 12:58 Go to previous messageGo to next message
You can get some pre-defined language packs from babel -
http://www.eclipse.org/babel
PW
Paul Webster
Re: jface wizard translate ok/cancel/next/previous button [message #334500 is a reply to message #334497] Thu, 12 February 2009 15:24 Go to previous messageGo to next message
I want the translation for a rcp project. How must babel be used? After
installing it to eclipse, the eclipse workbench uses the translation. I
need my eclipse unchanged.
How should babel be bound to my project? Shall i create a new plugin
project? Which components will babel affect?
Is there no more simple way? I already read something about
messages.properties and localized messages_en_EN.properties. But jface
wizard seems not to use them.
A tutorial or an article would be helpfull.
Thx,
markus
Re: jface wizard translate ok/cancel/next/previous button [message #334510 is a reply to message #334500] Fri, 13 February 2009 08:20 Go to previous messageGo to next message
"Ceeper" <nospam@somewhere.org> schrieb im Newsbeitrag
news:gn20hk$ak1$1@build.eclipse.org...
> I already read something about messages.properties and localized
> messages_en_EN.properties. But jface wizard seems not to use them.
JFace does use them (to my experience), but of course they must be in the
JFace package. Put your property files in »org.eclipse.jface«.
Michael Piefel
netCCM GmbH
Re: jface wizard translate ok/cancel/next/previous button [message #334512 is a reply to message #334500] Fri, 13 February 2009 09:02 Go to previous message
You should read thought the babel documentation, or post your question
to the babel newsgroup - eclipse.technology.babel
(http://www.eclipse.org/newsgroups/)
PW
Paul Webster
Previous Topic:Open XML file and read.
Next Topic:Best way to test an update site
Current Time: Sat Nov 22 23:43:02 EST 2025
Powered by FUDForum. Page generated in 0.03127 seconds
