Home » Eclipse Projects » Eclipse Platform » Additional Files for Deployed Product
Additional Files for Deployed Product [message #334456] Tue, 10 February 2009 11:12 Go to next message
Is there a way to automate the adding of external files / folders into my
deployed product ?
For instance I would like to add my "Reporting" folder and
"configuration.ini" file under the root folder. Currently what I do I just
manually copy those files and folders.
Re: Additional Files for Deployed Product [message #334492 is a reply to message #334456] Thu, 12 February 2009 11:22 Go to previous message
This depends on how you are building your product.
If you have a normal feature build, or a productBuild based on features,
then you can add root files using one of your features.
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/tasks/pde_rootfiles.htm
If you have a plugin based productBuild and are using 3.5 for your
builder, then there are some details at the bottom of that help page.
If you have 3.4 or earlier you will need to create a feature and get it
inserted into the build, which can be done by setting a property
"featureList", see
http://wiki.eclipse.org/PDE/Build#Including_files_in_the_roo t_of_my_build
-Andrew
> my deployed product ?
> just manually copy those files and folders.
Previous Topic:Rampant OutOfMemory errors in 3.4
Next Topic:measure runtime of a java program using Eclipse
Current Time: Thu Oct 30 22:23:49 EDT 2025
Powered by FUDForum. Page generated in 0.45032 seconds
