Home » Eclipse Projects » Eclipse Platform » Common Navigator showing expanded folders
Common Navigator showing expanded folders [message #334395] Fri, 06 February 2009 12:13 Go to next message
I am contributing to a common navigator from my plugin.xml
I would like to show different icons for an open "folder" and closed
"folder". By "folder" I mean things that have children as specified in the
content provider.
In the navigatorContent, I specify a labelProvider.
I thought that in my label provider's getImage() I could to check the
expanded state of the tree.
However, the label provider does not know about the tree that it is
connected to.
If I programmatically instanciate the label provider, I can pass the tree
to the constructor, however, when I am configuring it from the plugin.xml,
I assume the default constructor (i.e. no parameters) is used and so I
cannot pass in the tree.
Question: How do I show a different icon for open and closed folders, when
contributing to a common navigator using the plugin.xml file?
Thank you for your help
Re: Common Navigator showing expanded folders [message #334412 is a reply to message #334395] Sat, 07 February 2009 00:42 Go to previous messageGo to next message
You can get the CommonViewer from the CommonNavigator.getCommonViewer().
This is a normal JFace TreeViewer, from there you can get to the tree.
You can get your CommonNavigator instance by view Id if necessary.
HTH,
Francis
> the content provider.
> connected to.
> tree to the constructor, however, when I am configuring it from the
> plugin.xml, I assume the default constructor (i.e. no parameters) is
> used and so I cannot pass in the tree.
> when contributing to a common navigator using the plugin.xml file?
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Common Navigator showing expanded folders [message #334463 is a reply to message #334412] Tue, 10 February 2009 12:49 Go to previous messageGo to next message
I am getting closer...
I tried
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findView(viewID);
But under certain conditions I get
org.eclipse.ui.PartInitException: Warning: Detected recursive attempt by
part <my navigator view> to create itself (this is probably, but not
necessarily, a bug)
This happens when my navigator is behind another view (but I can see the
tab) when I click the tab to bring the view to the surface, I get this
error.
It appears that findView does more than simply return a pointer.
I can do it by calling getViewReferences(), iterating and getting the one
whose id matches the common navigator. But there should be a better way.
So.... Is there another way to just get a pointer to the view? It is kind
of unfortunate that I have to get the common navigator from the view id,
because it is exactly the common navigator that is calling my label
provider.
Help?
Re: Common Navigator showing expanded folders [message #334479 is a reply to message #334463] Wed, 11 February 2009 18:53 Go to previous message
Try this:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().findViewReference().getView(false)
This gets the part only if it has been actually created, so you should
not get those errors of it being in the middle of creation.
> I tried
> But under certain conditions I get org.eclipse.ui.PartInitException:
> Warning: Detected recursive attempt by part <my navigator view> to
> create itself (this is probably, but not necessarily, a bug)
> error.
> one whose id matches the common navigator. But there should be a better
> way.
> kind of unfortunate that I have to get the common navigator from the
> view id, because it is exactly the common navigator that is calling my
> label provider.
> Help?
Previous Topic:ant editor freezes in 3.4.1 (M20080911-1700)
Next Topic:Indention when using images in TreeViewer
Current Time: Fri Nov 21 17:38:53 EST 2025
Powered by FUDForum. Page generated in 0.10591 seconds
