Home » Eclipse Projects » Eclipse Platform » Cannot allocate memory MacOS 3.3.2 and 3.4.1
Cannot allocate memory MacOS 3.3.2 and 3.4.1 [message #334365] Wed, 04 February 2009 18:26 Go to next message
Getting "Could not reserve enough space for object heap" when running
eclipse at command line. Is this due to Eclipse on Mac not being 64 bit?
eclipse.ini:
-showsplash
org.eclipse.platform
-vmargs
-server
-d64
-Xdock:icon=../Resources/Eclipse.icns
-XstartOnFirstThread
-Xms1g
-Xmx3g
-XX:MaxPermSize=256m
-Dorg.eclipse.swt.internal.carbon.smallFonts
Re: Cannot allocate memory MacOS 3.3.2 and 3.4.1 [message #334375 is a reply to message #334365] Thu, 05 February 2009 14:19 Go to previous messageGo to next message
"Jason Rutherglen" <jason.rutherglen@gmail.com> wrote in message
news:a847407d16854c665ef269941a3558d9$1@www.eclipse.org...
Eclipse 3.5M5, just released, has a 64-bit Cocoa port. Of course, this is
an in-development milestone release, so you can decide for yourself whether
that is stable enough (and supported by enough third-party plugins) for your
needs.
As far as I know there is no 64-bit version of Eclipse 3.4 for Mac.
Information about supported platforms for Eclipse 3.4 is at
http://www.eclipse.org/eclipse/development/eclipse_project_p lan_3_4.html#TargetOperatingEnvironments .
Re: Cannot allocate memory MacOS 3.3.2 and 3.4.1 [message #334397 is a reply to message #334375] Fri, 06 February 2009 15:14 Go to previous messageGo to next message
You should be able to run a 32-bit eclipse release on 64-bit OS X iff your
VM is 32-bit. If your VM is jre 1.6 then this is not the case since it's
only available in a 64-bit flavour, but if it's pre-1.6 then it could be.
I've never heard of the error you're seeing before, so I'm just guessing
that you have a bit mismatch between your VM and eclipse.
Grant
"Walter Harley" <eclipse@cafewalter.com> wrote in message
news:gmfe35$mqg$1@build.eclipse.org...
bit?
whether
your
> needs.
Re: Cannot allocate memory MacOS 3.3.2 and 3.4.1 [message #334447 is a reply to message #334365] Mon, 09 February 2009 09:51 Go to previous message
> eclipse.ini:
> -showsplash
> -vmargs
> -server
> -d64
> -Xms1g
> -Xmx3g
You are trying to allocate 1G of memory at the start. This is quite large.
Try reducing the value to something smaller and see if it helps.
Previous Topic:Eclipse build problem
Next Topic:Console/UI Same Application
Current Time: Sat Nov 08 22:16:23 EST 2025
Powered by FUDForum. Page generated in 0.13170 seconds
