Home » Eclipse Projects » Eclipse Platform » Run As --> Ant Build... always creates new configuration
Run As --> Ant Build... always creates new configuration [message #334361] Wed, 04 February 2009 12:49 Go to next message
I'm using the 3.4.1 download of Eclipse (Ganymede).
When I launch an ant script from within a project using the context menu
option Run As --> Ant Build..., the Edit Configuration panel displays as
expected, but it ALWAYS starts with a NEW configuration. It is not using
an existing configuration already generated.
How can I change this behavior to use an exising configuration?
I had been using Rational Application Developer 7.0 (Eclipse based) and it
would reuse the already created launch configuration for each ant script
within the project. This makes it easy to make a quick change and proceed
with the launch via the context menu.
Re: Run As --> Ant Build... always creates new configuration [message #334370 is a reply to message #334361] Thu, 05 February 2009 10:45 Go to previous messageGo to next message
This problem does not exist in Eclipse 3.3.2 (Europa). I created bug
report 263791.
Re: Run As --> Ant Build... always creates new configuration [message #334373 is a reply to message #334370] Thu, 05 February 2009 12:50 Go to previous messageGo to next message
This is a duplicate of bug 215530 and is addressed in version 3.4.2.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215530
Re: Run As --> Ant Build... always creates new configuration [message #334374 is a reply to message #334361] Thu, 05 February 2009 12:52 Go to previous message
Thank you for logging the bug
This problem has been fixed in 3.4.2
See bug 215530
Darins
http://runnerwhocodes.blogspot.com
"Mark Shade" <shadey85@gmail.com> wrote in message
news:d4f25e00e624fa63af55ceb15638c031$1@www.eclipse.org...
Previous Topic:Ganymede "Help Contents" generating Error 500
Next Topic:Can I customize the ant build script exported by eclipse?
Current Time: Thu Jul 17 22:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.09939 seconds
