Home » Eclipse Projects » Eclipse Platform » Working with XML resources in Eclipse
Working with XML resources in Eclipse [message #334294] Sat, 31 January 2009 13:50 Go to next message
Hello Guys,
We will start a new software development project based on Eclipse platform.
We will use some XML-based resources in our project and need to work with
them (load, process, save).
Is there any Eclipse-specific tool and/or framework for XML binding,
processing, serialization, persistency?
Or we should use existing Java-based XML solutions for this purpose like
JAXB or other XML-APIs?
As I know, Eclipse is also massively using XML resources like plugin.xml
files...
Thanks, guys!
Csaba
Re: Working with XML resources in Eclipse [message #334296 is a reply to message #334294] Sat, 31 January 2009 15:56 Go to previous message
--------------030405020203060201090307
Csaba,
You asked much the same question on the EMF newsgroup. EMF effectively
gives you all the same types of things that JAXB or DOM give you, but
also a lot more that you're likely to need but haven't considered yet.
It's pretty easy to use this tutorial to try it out for your schema:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
If you invoke "Generate Test Code" EMF will generate a *.tests project
with an XyzExample.java that you can run stand alone to load and save
instances of your files.
Csaba wrote:
> Hello Guys,
> platform.
> with them (load, process, save).
> like JAXB or other XML-APIs?
> plugin.xml files...
> Thanks, guys!
> Csaba
<html>
<head>
http-equiv="Content-Type">
</head>
Csaba,<br>
<br>
Previous Topic:Configuring title of eclipse
Next Topic:display branch name in package explorer
Current Time: Sat Nov 08 20:01:45 EST 2025
Powered by FUDForum. Page generated in 0.03478 seconds
