| Problem decorator in Project Explorer does not display under Eclipse Platform distro [message #334288] |
Fri, 30 January 2009 13:19  |
Originally posted by: amir.nospam_pyrus.us
I have a plug-in that contributes a custom editor to the platform. The
editor is equipped with a checker that creates problem markers on the
resource when a problem is identified.
I install this plug-in under the 'dropins' folder under the eclipse.
When the plug-in is installed under the SDK distribution, problems
decorators display on the resource node in the 'Project Explorer'.
But, when the plug-in is installed under the platform binary
distribution, problem decorators do not display on the resource node in
the project Explorer'.
Do you know what I need to do to enable the display of problem decorator
under the platform binary distribution?
Thanks.
Amir
| Re: Problem decorator in Project Explorer does not display under Eclipse Platform distro [message #334461 is a reply to message #334430] |
Tue, 10 February 2009 12:23   |
Hi Amir,
I also work on an IDE based product where I need problem markers. When
building and running against the IDE itself I see the markers, but when
I run against my separate platfrom target: no markers.
I do have a problem with the label decorators, where they do not show if
I have one set of validators turned on and do show when it is off.
So buggy code in the builder may prevent the markers from showing.
I think that problem marking is dependent on some internal code in
JDT... :-(
Maybe we should file a bug
Where did you download your platform distro?
Maarten
Amir Kouchekinia wrote:
> No. I am not confusing the various navigators. In both cases I have the
> Resource Perspective on with project explorer view open.
> I have also checked the Label Decorators preferences, and under Platform
> Runtime both options are turned on: File Icons based on content
> analysis, and Linked Resources.
> Thanks.
> Amir
> Maarten Meijer wrote:
>> Are you sure you are not confusing the Project Explorer, Package
>> Explorer and Navigator?
>> Is the decorator enabled in the preferences view under
>> General/Appearance/Label Decorators?
>> maarten
>>> Any hints in this regard is appreciated.
>>> Thanks.
>>>> Hi,
>>>> The editor is equipped with a checker that creates problem markers
>>>> on the resource when a problem is identified.
>>>> in the project Explorer'.
>>>> decorator under the platform binary distribution?
>>>> Thanks.
>>>> Amir
| Re: Problem decorator in Project Explorer does not display under Eclipse Platform distro [message #334465 is a reply to message #334461] |
Tue, 10 February 2009 13:32   |
Hi Maarten,
Thanks for your response. The Platform Runtime Binaries are available
from Eclipse download page. See link for 3.4.1:
http://download.eclipse.org/eclipse/downloads/drops/R-3.4.1- 200809111700/index.php#PlatformRuntime
I don't know if this problem is a bug on the Platform IDE, or a missing
implementation on my part. Since Problem Markers are part of the
Platform IDE, it seems that the the Project Explorer resource nodes
should be equipped to display the icon decorations for the problems.
I am beginning to think that I should submit a bug report on this.
Amir
> Hi Amir,
> JDT... :-(
> Maarten
>> the Resource Perspective on with project explorer view open.
>> Platform Runtime both options are turned on: File Icons based on
>> content analysis, and Linked Resources.
>> Thanks.
>> Amir
>>> maarten
>>>> Thanks.
>>>>> Hi,
>>>>> node in the project Explorer'.
>>>>> Thanks.
>>>>> Amir
| Re: Problem decorator in Project Explorer does not display under Eclipse Platform distro [message #334467 is a reply to message #334465] |
Tue, 10 February 2009 13:57  |
I have submitted a bug report on this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264404
Amir
> Hi Maarten,
> Amir
>> Hi Amir,
>> when I run against my separate platfrom target: no markers.
>> if I have one set of validators turned on and do show when it is off.
>> JDT... :-(
>> Maarten
>>> Thanks.
>>> Amir
>>>> maarten
>>>>> Thanks.
>>>>>> Hi,
>>>>>> Thanks.
>>>>>> Amir
FUDForum. Page generated in 0.04909 seconds
