Home » Eclipse Projects » Eclipse Platform » Get image from platform image registry
Get image from platform image registry [message #334279] Fri, 30 January 2009 06:44 Go to next message
How to retrieve the image associated with a file type from the platform
image registry.
*.txt ---> icon text
*.java ---> icon with the letter J
As the package explorer treeview.
It is to create a little treeview from some files.
Re: Get image from platform image registry [message #334283 is a reply to message #334279] Fri, 30 January 2009 08:39 Go to previous messageGo to next message
You can use the Common Navigator/Project Explorer for any IResource
based file viewer. Basically, the workbench label provider for an IFile
does:
org.eclipse.ui.internal.ide.model.WorkbenchFile.getBaseImage (IResource)
The code in getBaseImage(*) looks up the content type and then tries to
get an icon from the editor registry.
PW
Paul Webster
Re: Get image from platform image registry [message #334285 is a reply to message #334283] Fri, 30 January 2009 12:47 Go to previous message
Thank-you Paul. That is exactly what I was looking for
Previous Topic:A command can have the checked state?
Next Topic:Automatically activate 'problems' view when errors occur in compilation
Current Time: Wed Nov 12 07:52:27 EST 2025
Powered by FUDForum. Page generated in 0.04389 seconds
