Home » Eclipse Projects » Eclipse Platform » Java heap space out of memory error
Java heap space out of memory error [message #334271] Fri, 30 January 2009 02:46 Go to next message
Hi All,
I have a plugin handling data for a specific type of files. The plugin
loads data from a file into a data module, then creates a multipage editor
to display and edit the data module, and finally writes data back to the
file.
The data module is created thru a factory class's getInstance(File
editingFile) static method, which enables the plugin to edit mulitiple
files at the same time. Inside the factory class, a static HashMap is used
to keep track of each java.io.File object and its corresponding data
module.
The plugin works just fine until when tests it with a fairly big file:
open the big file and then close it immediately for several times, a java
heap space out of memory error occurs.
With Java VisualVM, I found the plugin keeps about 8M heap memory
unreleased after being closed. I tried every way to solve it but could
not: it seems to me that all the widgets have been disposed, the data
module has been removed from the factory class.
Any ideas? Or is there any tool can help me to find who stays in the heap
not cleaned up?
Thanks in advance!
Sharon
http://www.eclaxy.com
Re: Java heap space out of memory error [message #334272 is a reply to message #334271] Fri, 30 January 2009 03:21 Go to previous messageGo to next message
Sharon schrieb:
> Hi All,
> plugin loads data from a file into a data module, then creates a
> multipage editor to display and edit the data module, and finally writes
> data back to the file. The data module is created thru a factory
> class's getInstance(File editingFile) static method, which enables the
> plugin to edit mulitiple files at the same time. Inside the factory
> class, a static HashMap is used to keep track of each java.io.File
> object and its corresponding data module.
> file: open the big file and then close it immediately for several times,
> a java heap space out of memory error occurs.
> heap not cleaned up?
> Thanks in advance!
> Sharon
Try to profile your project by using Eclipse TPTP or use JProfiler.
These tools offer memory analysis so you can pin down what exactly stays
in memory.
Jens
Re: Java heap space out of memory error [message #334289 is a reply to message #334271] Fri, 30 January 2009 16:46 Go to previous message
"Sharon" <sharon.floyd@eclaxy.com> wrote in message
news:d9fd030cf8e55a74e7d14bbdca55cba5$1@www.eclipse.org...
> module.
Just to check: you are removing the entry from that map, when the file is
closed, right?
I've found that whenever using these sort of static maps that track dynamic
data it is very important to think about the references. Sometimes it helps
to have it be a Map<File, WeakReference<Thing>> rather than just a Map<File,
Thing>, so that there isn't a circular reference that prevents the Thing
from ever actually being released.
Previous Topic:Automatically activate 'problems' view when errors occur in compilation
Next Topic:IOConsole Updater (Time of error: <timestamp>)
Current Time: Sun Nov 09 04:41:10 EST 2025
Powered by FUDForum. Page generated in 0.04277 seconds
