Home » Eclipse Projects » Eclipse Platform » how to specify GTK?
| how to specify GTK? [message #334268] |
Thu, 29 January 2009 20:35  |
Originally posted by: maggie.eclipse.gmail.com
Is there a way to specify a different version of libgtk to use? For
example, like how we could specify a Java with "-vm"?
We recently see random crashes at libgtk-x11-2.0(see below) with
Ganymede and CDT 5. A little bit googling shows GTK 2.0 is a 7 years old
release. I want to try out the latest GTK which is 2.14. But not sure
how to invoke Eclipse with the new GTK?
# An unexpected error has been detected by Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0090a464, pid=28615, tid=4160527264
# Java VM: Java HotSpot(TM) Server VM (1.6.0_03-b05 mixed mode)
# Problematic frame:
# C [libgtk-x11-2.0.so.0+0x1e8464]
# An error report file with more information is saved as hs_err_pid28615.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Any other ideas?
Maggie
| Re: how to specify GTK? [message #334339 is a reply to message #334287] |
Tue, 03 February 2009 15:48   |
Note that the eclipse launcher will be loading gtk to show the splash
screen. This is c code and independent of java, -Djava.library.path
won't work here. If you aren't using the splash screen, then swt will
be the first to load gtk and then java.library.path would work.
To change the gtk found by the launcher you would need to set an
environment variable LD_LIBRARY_PATH to point to the correct one.
(The launcher is just doing dlopen("libgdk-x11-2.0.so.0") )
-Andrew
Maggie wrote:
> Hi Tom,
> Thanks for the suggestions.
> Since I don't have "root" access to the system, so I can't try a) unless
> it's verified that is the cause of the crash.
> I will try b).
> Our system is RHEL4 with Ganymede+CDT 5.
> Thanks
> Maggie
> Tom Schindl wrote:
>> libgtk-x11-2.0.so.0 is a system library so you'd have to:
>> a) Upgrade your system to have the appropriate lib in your path
>> b) You could tell Java to search for native libs in an additional
>> location using -Djava.library.path
>> What system are you on? Which version of Eclipse are you trying?
>> Tom
>> Maggie schrieb:
>>> Hi,
>>> hs_err_pid28615.log
>>> Any other ideas?
>>> Thanks
>>> Maggie
| Re: how to specify GTK? [message #334521 is a reply to message #334339] |
Fri, 13 February 2009 15:43   |
Hi Andres, Tom,
Thanks for your suggestions.
We tried to run the same test case on REHL5.3 which has GTK 2.10 and
didn't see the crash. Somewhat confirmed that the crash is related to
the OS and GTK.
However, before we could upgrade all the system to RHEL 5.3, we need to
find an interim solution for users still on RHEL 5.03 with GTK 2.4.
We downloaded and compiled the latest GTK 2.14.7 (and all dependent)
library and installed them at /tmp/gtk-root-for-2.14.7/lib. We then
tried to set both LD_LIBRARY_PATH and -Djava.library.path to where the
newer version GTK was installed, but Eclipse still crashes :-(
In the "Dynamic libraries" section of the hs_err_pid.log, there are
still pointers to /usr/lib for GTK 2.4 instead of the new location for
GTK 2.14.
How to make sure the new library path is picked up?
Below is the output from "grep -n gtk hs_err_pid*.log" (with host and
user specific information modified). The only reference to
/tmp/gtk-root-for-2.14.7 is in LD_LIBRARY_PATH and -Djava.library.path.
> 8:# C [libgtk-x11-2.0.so.0+0x1e8498]
> 41:C [libgtk-x11-2.0.so.0+0x1e8498]
> 46:C [libswt-pi-gtk-3449.so+0x328cd] Java_org_eclipse_swt_internal_gtk_OS__1g_1main_1context_1ite ration+0x20
> 47:j org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(IZ )Z+0
> 48:j org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(IZ) Z+9
> 62:j org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(IZ )Z+0
> 63:j org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(IZ) Z+9
> 223:00722000-009ca000 r-xp 00000000 68:01 1073922 /usr/lib/libgtk-x11-2.0.so.0.400.13
> 224:009ca000-009d3000 rwxp 002a8000 68:01 1073922 /usr/lib/libgtk-x11-2.0.so.0.400.13
> 321:52146000-52149000 r-xp 00000000 68:01 1200134 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-png.so
> 322:52149000-5214a000 rwxp 00003000 68:01 1200134 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-png.so
> 398:52ab5000-52abf000 r-xp 00000000 00:2c 2003498 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-cai ro-gtk-3449.so
> 399:52abf000-52ac0000 rwxp 00009000 00:2c 2003498 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-cai ro-gtk-3449.so
> 404:52c3d000-52c43000 r-xp 00000000 00:2c 2003496 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-atk -gtk-3449.so
> 405:52c43000-52c44000 rwxp 00005000 00:2c 2003496 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-atk -gtk-3449.so
> 474:53519000-5351e000 r-xp 00000000 68:01 1200130 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-gif.so
> 475:5351e000-5351f000 rwxp 00004000 68:01 1200130 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-gif.so
> 486:53592000-535e7000 r-xp 00000000 00:2c 2003495 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-pi- gtk-3449.so
> 487:535e7000-535e9000 rwxp 00054000 00:2c 2003495 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-pi- gtk-3449.so
> 489:535ea000-535ed000 r-xp 00000000 00:2c 2003494 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-gtk -3449.so
> 490:535ed000-535ee000 rwxp 00002000 00:2c 2003494 <eclipse-install-location> /configuration/org.eclipse.osgi/bundles/398/1/.cp/libswt-gtk -3449.so
> 498:535fe000-53610000 r-xs 001d8000 00:2c 12779120 <eclipse-install-location>/plugins/org.eclipse.swt.gtk.linux.x86_3.4.1.v3449c.jar
> 526:53934000-53937000 r-xp 00000000 68:01 1200129 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-bmp.so
> 527:53937000-53938000 rwxp 00002000 68:01 1200129 /usr/lib/gtk-2.0/2.4.0/loaders/libpixbufloader-bmp.so
> 528:53940000-5394c000 r-xp 00000000 68:01 1200766 /usr/lib/gtk-2.0/2.4.0/engines/libbluecurve.so
> 529:5394c000-5394d000 rwxp 0000b000 68:01 1200766 /usr/lib/gtk-2.0/2.4.0/engines/libbluecurve.so
> 544:53b39000-53b44000 r-xp 00000000 00:2c 23342803 <eclipse-install-location> /plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101. R34x_v20080805/eclipse_1115.so
> 545:53b44000-53b45000 rwxp 0000a000 00:2c 23342803 <eclipse-install-location> /plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101. R34x_v20080805/eclipse_1115.so
> 612:jvm_args: -Dosgi.requiredJavaVersion=1.5 -Xms2048m -Xmx2048m -XX:PermSize=256m -XX:MaxPermSize=512m -Djava.library.path=/tmp/gtk-root-for-2.14.7/lib
> 613:java_command: <eclipse-install-location> /plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819 .jar -os linux -ws gtk -arch x86 -showsplash -launcher <eclipse-install-location>/eclipse -name Eclipse --launcher.library <eclipse-install-location> /plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101. R34x_v20080805/eclipse_1115.so -startup <eclipse-install-location> /plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819 .jar -exitdata 20f8007 -vm /auto/integration/jdk1.6.0_03/bin/java -vmargs -Dosgi.requiredJavaVersion=1.5 -Xms2048m -Xmx2048m -XX:PermSize=256m -XX:MaxPermSize=512m -Djava.library.path=/ws/jmagnuso-sjc/gtk-root-for-2.14.7/lib -jar <eclipse-install-location> /plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819 .jar
> 618:LD_LIBRARY_PATH=/auto/integration/jdk1.6.0_03/jre/lib/i3 86/server:/auto/integration/jdk1.6.0_03/jre/lib/i386:/auto/i ntegration/jdk1.6.0_03/jre/../lib/i386:/tmp/gtk-root-for-2.1 4.7/lib
Maggie
> -Andrew
> Maggie wrote:
>> Hi Tom,
>> unless it's verified that is the cause of the crash.
>> I will try b).
>> Thanks
>> Maggie
>> Tom Schindl wrote:
>>> Hi,
>>> Tom
>>> Maggie schrieb:
>>>> Hi,
>>>> old
>>>> hs_err_pid28615.log
>>>> Any other ideas?
>>>> Thanks
>>>> Maggie
| Re: how to specify GTK? [message #334938 is a reply to message #334521] |
Tue, 10 March 2009 14:54   |
Hi Andrew, et al,
Can you provide a pointer on how to get the launcher's source code?
Below is the result of "grep libgtk strace_*" where "strace_*" contain
output from "strace".
1:
strace_ff.17110:9403:open(" /auto/cliq/integration/jdk1.6.0_03/bin/../jre/lib/i386/jli/l ibgtk-x11-2.0.so.0 ",
O_RDONLY) = -1 ENOENT (No such file or directory)
2:
strace_ff.17110:9404:open(" /auto/cliq/integration/jdk1.6.0_03/jre/lib/i386/server/libgt k-x11-2.0.so.0 ",
3:
strace_ff.17110:9405:open(" /auto/cliq/integration/jdk1.6.0_03/jre/lib/i386/libgtk-x11-2 .0.so.0 ",
4:
strace_ff.17110:9406:open(" /ws/jmagnuso-sjc/gtk-root-for-2.14.7/lib/libgtk-x11-2.0.so.0 ",
O_RDONLY) = 9
5: strace_ff.17110:9413:open("/usr/lib/libgtk-x11-2.0.so.0", O_RDONLY) = 9
6: strace_ff.17110:162570:write(1, " [libgtk-x11-2.0.so.0+0x1e0953]",
32) = 32
7: strace_ff.17110:162592:write(189, "
[libgtk-x11-2.0.so.0+0x1e0953]", 32) = 32
8: strace_ff.17110:162787:write(189, "
9: strace_ff.17110:162790:write(189, "
[libgtk-x11-2.0.so.0+0x1e841e]", 32) = 32
10: strace_ff.17110:162793:write(189, "
[libgtk-x11-2.0.so.0+0x1e84a3]", 32) = 32
11: strace_ff.17110:163638:read(197, " /usr/lib/libgtk-x11-2.0.so.0.4",
32) = 32
12: strace_ff.17110:163639:write(189, "
/usr/lib/libgtk-x11-2.0.so.0.4", 32) = 32
As you can see that our private library was opened successfully (line 4)
However, it opens GTK under /usr/lib again later on (line 5).
I'm puzzled by why it would open GTK under /usr/lib (line 5) when line 4
returned success. Would like to get the launcher's source code and debug
a bit.
Maggie
Maggie wrote:
> Hi Andres, Tom,
> the OS and GTK.
> GTK 2.14.
>> 1200134
>> 1200134
>> 2003498
>> 2003498
>> 2003496
>> 2003496
>> 1200130
>> 1200130
>> 2003495
>> 2003495
>> 2003494
>> 2003494
>> 12779120
>> 1200129
>> 1200129
>> 1200766
>> 1200766
>> 23342803
>> 23342803
>> 613:java_command:
>> -startup
> Thanks
> Maggie
>> -Andrew
>> Maggie wrote:
>>> Hi Tom,
>>> I will try b).
>>> Thanks
>>> Maggie
>>> Tom Schindl wrote:
>>>> Hi,
>>>> Tom
>>>> Maggie schrieb:
>>>>> Hi,
>>>>> years old
>>>>> hs_err_pid28615.log
>>>>> Any other ideas?
>>>>> Thanks
>>>>> Maggie
| Re: how to specify GTK? [message #335004 is a reply to message #334938] |
Sun, 15 March 2009 12:26   |
Just to close the loop of this issue. It turned out that we were using
32-bit Eclipse while the GTK 2.14 was built as 64-bit. Compiling one as
32-bit and specify the path to it in LD_LIBRARY_PATH solved the crash
problem.
As simple as that:-)
Looking back, this should be the first thing that we should have
suspected. If not counting the time spent on troubleshooting the
mismatched libraries (32-bit vs. 64-bit), building newer version of GTK
library is the most time consuming part as you would need to build all
its dependencies as well. But overall, it's pretty straightforward.
Maggie
Maggie wrote:
> Hi Andrew, et al,
> 1:
> 2:
> 3:
> 4:
> O_RDONLY) = 9
> 32) = 32
> 7: strace_ff.17110:162592:write(189, " [libgtk-x11-2.0.so.0+0x1e0953]",
> 32) = 32
> 8: strace_ff.17110:162787:write(189, " [libgtk-x11-2.0.so.0+0x1e0953]",
> 32) = 32
> 9: strace_ff.17110:162790:write(189, " [libgtk-x11-2.0.so.0+0x1e841e]",
> 32) = 32
> 10: strace_ff.17110:162793:write(189, " [libgtk-x11-2.0.so.0+0x1e84a3]",
> 32) = 32
> 32) = 32
> 12: strace_ff.17110:163639:write(189, " /usr/lib/libgtk-x11-2.0.so.0.4",
> 32) = 32
> a bit.
> Thanks
> Maggie
> Maggie wrote:
>> Hi Andres, Tom,
>> the OS and GTK.
>> to find an interim solution for users still on RHEL 5.03 with GTK 2.4.
>> GTK 2.14.
>>> 1200134
>>> 1200134
>>> 2003498
>>> 2003498
>>> 2003496
>>> 2003496
>>> 1200130
>>> 1200130
>>> 2003495
>>> 2003495
>>> 2003494
>>> 2003494
>>> 12779120
>>> 1200129
>>> 1200129
>>> 1200766
>>> 1200766
>>> 23342803
>>> 23342803
>>> 613:java_command:
>>> -startup
>> Thanks
>> Maggie
>>> will be the first to load gtk and then java.library.path would work.
>>> -Andrew
>>> Maggie wrote:
>>>> Hi Tom,
>>>> I will try b).
>>>> Thanks
>>>> Maggie
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> Tom
>>>>> Maggie schrieb:
>>>>>> Hi,
>>>>>> years old
>>>>>> hs_err_pid28615.log
>>>>>> Any other ideas?
>>>>>> Thanks
>>>>>> Maggie
| Re: how to specify GTK? [message #335008 is a reply to message #334938] |
Mon, 16 March 2009 09:07   |
Sorry for missing this earlier, the source code for the launcher is in
cvs at
dev.eclipse.org:/cvsroot/rt/org.eclipse.equinox/framework/bu ndles/org.eclipse.equinox.executable
Maggie wrote:
> Hi Andrew, et al,
> 1:
> 2:
> 3:
> 4:
> O_RDONLY) = 9
> 32) = 32
> 32) = 32
> 32) = 32
> 32) = 32
> 32) = 32
> 32) = 32
> 32) = 32
> a bit.
> Thanks
> Maggie
> Maggie wrote:
>> Hi Andres, Tom,
>> the OS and GTK.
>> GTK 2.14.
>>> 1200134
>>> 1200134
>>> 2003498
>>> 2003498
>>> 2003496
>>> 2003496
>>> 1200130
>>> 1200130
>>> 2003495
>>> 2003495
>>> 2003494
>>> 2003494
>>> 12779120
>>> 1200129
>>> 1200129
>>> 1200766
>>> 1200766
>>> 23342803
>>> 23342803
>>> 613:java_command:
>>> -startup
>> Thanks
>> Maggie
>>> -Andrew
>>> Maggie wrote:
>>>> Hi Tom,
>>>> I will try b).
>>>> Thanks
>>>> Maggie
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> Tom
>>>>> Maggie schrieb:
>>>>>> Hi,
>>>>>> years old
>>>>>> hs_err_pid28615.log
>>>>>> Any other ideas?
>>>>>> Thanks
>>>>>> Maggie
| Re: how to specify GTK? [message #335064 is a reply to message #335008] |
Fri, 20 March 2009 00:52  |
Hi Andrew,
Thanks for the response.
As mentioned in my later post, we've managed to find the source of the
executable and found out our problem being compiled the GTK library for
wrong architecture. Rebuild the library as 32 bit to match our
executable solved the problem.
Maggie
> cvs at
> Maggie wrote:
>> Hi Andrew, et al,
>> 1:
>> 2:
>> 3:
>> 4:
>> O_RDONLY) = 9
>> O_RDONLY) = 9
>> 4) However, it opens GTK under /usr/lib again later on (line 5).
>> 4 returned success. Would like to get the launcher's source code and
>> debug a bit.
>> Thanks
>> Maggie
>> Maggie wrote:
>>> Hi Andres, Tom,
>>> the OS and GTK.
>>> the newer version GTK was installed, but Eclipse still crashes :-(
>>> for GTK 2.14.
>>>> 1200134
>>>> 1200134
>>>> 2003498
>>>> 2003498
>>>> 2003496
>>>> 2003496
>>>> 1200130
>>>> 1200130
>>>> 2003495
>>>> 2003495
>>>> 2003494
>>>> 2003494
>>>> 12779120
>>>> 1200129
>>>> 1200129
>>>> 1200766
>>>> 1200766
>>>> 23342803
>>>> 23342803
>>>> 613:java_command:
>>>> -startup
>>> Thanks
>>> Maggie
>>>> splash screen. This is c code and independent of java,
>>>> -Djava.library.path won't work here. If you aren't using the splash
>>>> screen, then swt will be the first to load gtk and then
>>>> -Andrew
>>>> Maggie wrote:
>>>>> Hi Tom,
>>>>> I will try b).
>>>>> Thanks
>>>>> Maggie
>>>>> Tom Schindl wrote:
>>>>>> Hi,
>>>>>> Tom
>>>>>> Maggie schrieb:
>>>>>>> Hi,
>>>>>>> years old
>>>>>>> sure
>>>>>>> hs_err_pid28615.log
>>>>>>> Any other ideas?
>>>>>>> Thanks
>>>>>>> Maggie
Current Time: Thu Nov 06 12:20:57 EST 2025
Powered by FUDForum. Page generated in 0.57528 seconds
