Home » Eclipse Projects » Eclipse Platform » How to change Console encoding?
How to change Console encoding? [message #334237] Wed, 28 January 2009 09:35 Go to next message
Hello!
I have a problem of remote debugging an application which run on a JVM
with different encoding (UTF-8) than is installed on my Eclipse
installation (MS932). I'd like to see the output this installation gives
within a proper encoding (different than my workbench's).
I know of one way within Run configuration's common tab (however due to a
bug with the software I am using I am unable to use it).
I'd like to ask if there is another way of changing the encoding of the
console only?
Blazej
Re: How to change Console encoding? [message #334300 is a reply to message #334237] Mon, 02 February 2009 05:04 Go to previous messageGo to next message
Blazej Kroll pisze:
> Hello!
> a bug with the software I am using I am unable to use it).
> console only?
> Blazej
I cannot recall any other way, however you could try -d file.encoding.
kind regards,
Jakub
Re: How to change Console encoding? [message #334328 is a reply to message #334300] Tue, 03 February 2009 07:16 Go to previous messageGo to next message
So you can not
Re: How to change Console encoding? [message #334530 is a reply to message #334328] Mon, 16 February 2009 07:36 Go to previous message
Blazej Kroll pisze:
> So you can not
Sorry my previously sent messaged, it got cut. Here is the complete
reply again:
So you can not change the console encoding anywhere else within the
Eclipse environment? (Got curious if this is kind of a bug or should be
an enhancement maybe?)
Blazej
Previous Topic:Open Resource window issue
Next Topic:List Open Files
Current Time: Thu Nov 20 22:35:23 EST 2025
Powered by FUDForum. Page generated in 0.16960 seconds
