| Passing parameters while executing command programmatically [message #334206] |
Mon, 26 January 2009 12:34  |
I want to execute my command programmatically. I've defined a command in
plugin.xml and it has a corresponding handler (also defined in
plugin.xml). The following code calls the handler programmatically:
IHandlerService handlerService = (IHandlerService)
getSite().getService(IHandlerService.class);
try {
handlerService.executeCommand("MyCommandId", null);
catch (Exception ex) {
throw new RuntimeException("MyCommandId not found");
This works, but I want to pass in parameters to my handler. My handler has
the execute method and it takes ExecutionEvent object. The signature looks
like this:
public Object execute(ExecutionEvent event) throws ExecutionException {}
But, handlerService.executeCommand take Event as the second parameter and
not ExecutionEvent.
Is there any way to pass the parameters to my handler while calling it
programmatically?
Thanks in advance,
- Raja.
| Re: Passing parameters while executing command programmatically [message #334236 is a reply to message #334230] |
Wed, 28 January 2009 09:23  |
Raja Kannappan wrote:
> I followed your steps but ParameterizedCommand.generateCommand(command,
> params) returns null, even though command and params are valid objects.
> My code looks like this:
> ICommandService commandService = (ICommandService)
> getSite().getService(ICommandService.class);
> Command showElement =
> commandService.getCommand("com.xyz.commands.showElement");
> Map<String, Object> params = new HashMap<String,
> Object>();
> params.put("viewId", ID);
> ParameterizedCommand paramShowElement =
> ParameterizedCommand.generateCommand(showElement, params);
> ExecutionEvent execEvent =
> handlerService.createExecutionEvent(paramShowElement, new Event());
> try {
> showElement.executeWithChecks(execEvent);
> } catch (Exception ex) {
> throw new RuntimeException("com.xyz.commands.showElement
> could not be executed");
> Am I missing something? Thanks,
Does your command definition include a commandParameter? parameters are
defined with the command, and tend to be static in nature (or simple,
a viewId is acceptable). For example, our showView command takes the
viewId, and our definition looks like:
<command
name="%command.showView.name"
description="%command.showView.description"
categoryId="org.eclipse.ui.category.views"
id="org.eclipse.ui.views.showView"
defaultHandler="org.eclipse.ui.handlers.ShowViewHandler">
<commandParameter
id="org.eclipse.ui.views.showView.viewId"
name="%command.showView.viewIdParameter"
values="org.eclipse.ui.internal.registry.ViewParameterValues " />
<commandParameter
id="org.eclipse.ui.views.showView.makeFast"
name="%command.showView.makeFastParameter"
optional="true">
</commandParameter>
</command>
[/xml]
Other than that, use
handlerService.createExecutionEvent(paramShowElement, null) to create
the ExecutionEvent (if you don't have an SWT event, don't create one).
PW
Paul Webster
FUDForum. Page generated in 0.04232 seconds
