Home » Eclipse Projects » Eclipse Platform » Disappearing error markers in Projects Explorer
Disappearing error markers in Projects Explorer [message #334194] Mon, 26 January 2009 04:17 Go to next message
Hi.
I am doing validation on some files and adding an error marker to them
when validation fails. Up until yesterday everything worked fine, with
the Problems view showing the error and the file and its parents being
decorated with an error decorator in the Projects Explorer.
All of a sudden, although the marker gets correctly added to the IFile
and the Problems view gets updated correctly, the decoration in the
Projects Explorer no longer appears.
I am at a loss as to the possible reason for this. It occurs both under
Ganymede and under Europa. Any ideas?
TIA,
B.
                                   Barbara Rosi-Schwartz
                   Etish Limited [http://www.etish.org]
 /  o,o  \       The proud parents of ORMF & Useme
 |) ::: (|       The Open Requirements Management Framework
====w=w====      [http://www.eclipse.org/ormf]
Re: Disappearing error markers in Projects Explorer [message #334199 is a reply to message #334194] Mon, 26 January 2009 08:27 Go to previous messageGo to next message
I would check the error logs of your rumtime eclipse under
<workspace>/.metadata/.log when this starts happening. Any errors?
Failing that, you might need to open a bug against
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI&short_desc=[CommonNavigator]
for the Project Explorer
PW
Paul Webster
Re: Disappearing error markers in Projects Explorer [message #334209 is a reply to message #334199] Mon, 26 January 2009 13:58 Go to previous message
> PW
Thank you for your reply, Paul.
I forgot to mention it in my previous post, but no, no error message
appear in either the log or anywhere else.
I have filed this as a bug
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=262415) as per your
suggestion.
Thank you very much and kind regards,
B.
Blog: http://www.brs4etish.blogspot.com
Previous Topic:Inoperational shortcuts
Next Topic:IFile.create and/or IFile.setContents are often very slow
Current Time: Fri Nov 14 19:23:25 EST 2025
Powered by FUDForum. Page generated in 0.04192 seconds
