Home » Eclipse Projects » Eclipse Platform » Compiling annotations with inconsistant behavior
Compiling annotations with inconsistant behavior [message #334182] Fri, 23 January 2009 12:35 Go to next message
Consider the following code scenerios...
// Case 1
// Code shows error in eclipse
@MappedSuperclass
class Parent
public static final String TABLE = "PARENT";
public static final InheritanceType INH = InheritanceType.SINGLE_TABLE;
@Entity
@Table(name=Parent.TABLE) <<< Works fine
@Inheritance(strategy=Parent.INH) <<< ERROR, requires enum constant
class Child extends Parent
// Case 2
// Code shows no error in eclipse
// But fails to compile via command line using say maven
@MappedSuperclass
class Parent
public static final int INH = 0;
@Entity
@Table(name=Parent.TABLE) <<< Works fine everywhere
@Inheritance(strategy = Parent.INH == 0
? InheritanceType.X
: InheritanceType.Y) <<< NO ERROR in eclipse
The latter case fails compile time via maven with the same error as
before, that the annotation requires an enum constant value for
Inheritance.
Why does eclipse have an inconsistant behvaior in that case?
I am using Ganymede and JDK 1.6 (however same behavior seen with JDK 1.5)
Thanks.
Re: Compiling annotations with inconsistant behavior [message #334183 is a reply to message #334182] Fri, 23 January 2009 12:38 Go to previous messageGo to next message
small note: ignore the fact that I used .X and .Y for case 2.
Everything is accurate to javax.persistance.InheritanceType enum.
All imports are correct.
Re: Compiling annotations with inconsistant behavior [message #334190 is a reply to message #334183] Sat, 24 January 2009 20:54 Go to previous messageGo to next message
"Priyajeet " <priyajeet.hora@gmail.com> wrote in message
news:e4ffaf5b42e64efbd92a296dc955d5b8$1@www.eclipse.org...
For future reference, questions like this are best posted to
eclipse.tools.jdt, not eclipse.platform.
For those (like me) who don't have the JPA annotations memorized, the
following code will reproduce the problem:
public class Foo {
protected enum E { E1, E2 }
protected @interface AnnoE {
E value();
@AnnoE(true ? E.E1 : E.E2)
public void foo() {}
Eclipse does not error; javac 1.6 does:
D:\eclipse\ws\priyajeet\Foo\src>javac -d ../bin -cp . Foo.java
Foo.java:8: an enum annotation value must be an enum constant
1 error
Now, whether this is a javac bug or an Eclipse bug is something for the
language lawyers to wrangle over. The rules about enum constants are a bit
funky, and so are the rules about the ternary operator; answering questions
like that usually involves digging into the nitty gritty details of the JLS
and sometimes even then there are ambiguities.
Anyway, I didn't see an existing bug about it in either the Sun or Eclipse
bug databases, so I've entered https://bugs.eclipse.org/262304 to track it.
Re: Compiling annotations with inconsistant behavior [message #334205 is a reply to message #334190] Mon, 26 January 2009 11:55 Go to previous message
"Walter Harley" <eclipse@cafewalter.com> wrote in message
news:glggnv$ri4$1@build.eclipse.org...
> it.
The JDT guys have identified this as an Eclipse bug, and have fixed it for
3.5 M5.
Previous Topic:LTK rename refactoring - overriding the icons
Next Topic:Update-site not found new features
Current Time: Sat Jul 26 09:27:46 EDT 2025
Powered by FUDForum. Page generated in 0.04730 seconds
