| XML Document Validation [message #33900] | Tue, 02 December 2003 13:59  |  |
| Eclipse User  |  |  |  |  | Originally posted by: cipher8000.yahoo.com
 Hi Ed,
 Is there any plans in future to implement xml instance validation using
 eclipse xsd model.? Can i hook "eclipse xsd model" to Xerces parser to do
 validation for xml instances? Xerces does some decent xml validation against
 schemas..but the problem is they use Xerces Schema model.
 I really appricate if you provide some points/directions to implement
 validation on top of eclipse xsd model.?
 thanks
 -muruga
| Re: XML Document Validation [message #33940 is a reply to message #33900] | Tue, 02 December 2003 15:10  |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 Muruga,
 No, there aren't any immediate plans to do this, but the low-grade pressure to
 do so has been there for quite some time.  Some pieces you'd need are available
 already.  I.e., you can use XSDSimpleTypeDefinition.assess to do validation of
 simple type literals.  Also, in XSDEditor.GenericXMLResourceImpl there is some
 code that illustrates how the DFA on an XSDParticle can be used to validate
 element content.  Unfortunately, full validation would be a large piece of work,
 but perhaps these simple pieces will be sufficient for what you actually want to
 do...
 Muruga Chinnananchi wrote:
 > Hi Ed,
 > thanks
 > -muruga
| Re: XML Document Validation [message #581353 is a reply to message #33900] | Tue, 02 December 2003 15:10  |  |
| Eclipse User  |  |  |  |  | Muruga,
 do...
 > Hi Ed,
 > thanks
 > -muruga
FUDForum. Page generated in 0.06102 seconds
