Home » Eclipse Projects » Eclipse Platform » LTK rename refactoring - overriding the icons
LTK rename refactoring - overriding the icons [message #334179] Fri, 23 January 2009 10:25 Go to next message
Does anyone know if its possible (and how :)) to override the icons of the
LTK refactoring tree viewer in a public way? i.e. how to provide my own
lable provider for my found changes.
Thanks in advance.
Adam
Re: LTK rename refactoring - overriding the icons [message #334200 is a reply to message #334179] Mon, 26 January 2009 09:25 Go to previous message
Originally posted by: zoltan.balogh.optxware.com
Adam írta:
> Thanks in advance.
> Adam
Hi Adam,
I faced with the same problem, and I haven’t got any good, generic
solution yet. By the way I found some workaround, but it has a huge
limitation.
LTK uses PreviewNode to represents the Change nodes in the preview page.
As far as I found (but I’m not sure), we can only adapt the
TextEditBasedChange changes so If we make our own change extended form
TextEditBasedChange, we can adapt it to our own PreviewNode
implementation where getImageDescriptor() can be overridden.
But as I mentioned, the huge limitation of this solution that we can use
only TextEditBasedChange changes and these changes will show the compare
window in the bottom of the preview page. Furthermore there can be a lot
of cases when the TextEditBasedChange doesn’t fit for our goal.
Maybe it can help a little bit, but I’m also interested in the generic
solution! :)
Zoli
Previous Topic:filetransfer ...
Next Topic:Compiling annotations with inconsistant behavior
Current Time: Tue Nov 04 13:41:20 EST 2025
Powered by FUDForum. Page generated in 0.02985 seconds
