Home » Eclipse Projects » Eclipse Platform » pde build dependencies
pde build dependencies [message #334168] Thu, 22 January 2009 22:06
Originally posted by: adam.example.com
I am using pde build to build a product as a part of a larger build
process. I would like the build to run only when the deps change - such
as the java files. Right now, it is running on every build - which
takes a while. Is there any obvious way to set this up?
thanks,
adam
Previous Topic:Adding jars from file system to runtime classpath
Next Topic:Programatically set Problem view filter
Current Time: Mon Nov 17 05:11:41 EST 2025
Powered by FUDForum. Page generated in 0.03495 seconds
