Home » Eclipse Projects » Eclipse Platform » Platform extensibility
Platform extensibility [message #334152] Thu, 22 January 2009 03:57 Go to next message
I understand that such a big project as Eclipse, used in so many ways by
so many people, has to be accessed by a well defined public API.
Sometimes, I need to use the Platform in ways not initially thought by the
Eclipse designers. So I need to use private API on my own risk. I assume
the risk that internal API's can change in the future at any time.
For example. I need to derive org.eclipse.swt.widget.Table, to tweak a
little its behaviour.
Problem:
This class has many members I need that can only be accessed from classes
in the same package.
Solutions I have tried:
1) Extend in a 3rd party plugin and use the same package. Problem:
different class loaders. I have problems even when using reflection.
2) Place my custom classes in a fragment extending org.eclipse.swt plugin.
Problem: my classes have full access to SWT internals, but cannot be seen
from the outside.
3) Import the plugin as a project. This solution works, but I have to
import hundreds of classes, just for adding one own class. In addition
the org.eclipse.swt.win32.win32.x86 plugin cannot be built by the product
export tool, it crashed. So in my humble opinion, this solution is not
optimal.
So, what is the recommended way to extend the Platform in special cases
where internal API use is needed?
Re: Platform extensibility [message #334207 is a reply to message #334152] Mon, 26 January 2009 12:36 Go to previous messageGo to next message
Maybe this could be useful:
http://www.eclipse.org/equinox/incubator/aspects/index.php
Some experience somebody would like to share?
David Pérez wrote:
> Problem:
> from the outside.
> optimal.
Re: Platform extensibility [message #334216 is a reply to message #334152] Mon, 26 January 2009 15:01 Go to previous message
"David "P
Previous Topic:IFile.create and/or IFile.setContents are often very slow
Next Topic:If you use the Common Navigator please test with this weeks I-build
Current Time: Fri Oct 24 07:38:08 EDT 2025
Powered by FUDForum. Page generated in 0.05344 seconds
