Home » Eclipse Projects » Eclipse Platform » Editor window persistence problem
Editor window persistence problem [message #334069] Mon, 19 January 2009 00:29 Go to next message
I have a multipage editor based on eclipse platform.
A bug i noticed in my editor is that when i delete a file from the
navigator window, if the file is the active editor in the editor window,
the editor continues to stay open(as though the file hasnt been deleted
i.e, it does not close), even though the file has been removed from the
navigator view.
Eclipse itself works perfectly when i tried this, so im not sure what i ve
missed.
Thanks in advance,
Sheela
Re: Editor window persistence problem [message #334084 is a reply to message #334069] Mon, 19 January 2009 14:29 Go to previous message
Something based on AbstractTextEditor is using the IDocument,
IDocumentProvider, and
org.eclipse.ui.texteditor.AbstractTextEditor.ElementStateLis tener to
close itself when the element is deleted.
If you are processing a FileEditorInput you would have to add your own
IResourceChangeListener (or appropriate workspace listener) so if the
resource is deleted you can close your editor.
PW
Paul Webster
Previous Topic:[PDE Build] Feature builds question
Next Topic:Best Practice for FormEditor's dirtyState/saving
Current Time: Mon Nov 24 05:28:31 EST 2025
Powered by FUDForum. Page generated in 0.04557 seconds
