Home » Eclipse Projects » Eclipse Platform » [PDE Build] Feature builds question
[PDE Build] Feature builds question [message #334067] Sun, 18 January 2009 07:31 Go to next message
Originally posted by: tina.young.nospam.hotmail.com
As a part of a new assignment I need to update the way that our auto-build
system creates the output. The system is very stanard PDE build.
I have 2 problems / questions
1.
The output of the build is a ZIP file that contains the feature and all the
plugins
Is it possible to make the ZIP file to get the same version number as the
feature?
(is this the 'standard' naming convention - perhaps with builddate?)
2.
The ZIP file is created with the following layout
|-- eclipse
| --- features
| --- plugins
This layout seems to be very common when downloading ZIP files.
But we have also seeen a more flat structure (with the eclipse level
removed):
| --- features
| --- plugins
Is this possible to achive with PDE build ?
(e.g. without doing some re-packaging wiht own code?)
Wich layout / structure of the 2 above is to prefer?
Any help/comments/suggestions in this matter appreciated
regards,
Tina
Re: [PDE Build] Feature builds question [message #334083 is a reply to message #334067] Mon, 19 January 2009 13:23 Go to previous message
Tina wrote:
> 1.
> plugins
> feature?
I added lines to my postBuild step:
<move
file=" ${buildDirectory}/${buildLabel}/${topLevelElementId}-${build Id}-group.group.group.zip "
tofile=" ${buildDirectory}/${buildLabel}/${topLevelElementId}-${build Label}.zip "
But I had set groupConfigurations=true so I only got one big zip
> 2.
> |-- eclipse
> | --- features
> | --- plugins
> removed):
> | --- features
> | --- plugins
Prefer the first one, unless you have a specific need for the second.
It is the most useful for external extension locations (<3.4) and
eclipse/dropins (>=3.4)
PW
Paul Webster
Previous Topic:Turning on key bindings in an editor
Next Topic:Editor window persistence problem
Current Time: Mon Jul 21 21:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.04622 seconds
