Home » Eclipse Projects » Eclipse Platform » search results vs. plugin.xml
search results vs. plugin.xml [message #334059] Fri, 16 January 2009 16:01 Go to next message
Originally posted by: first.last.oracle.com
When I search for references to a class using the command
Search-References-Workspace (Ctrl-Shift-G), the search results
will not always display references to the class from plugin.xml.
Pseudo-example:
I have an implementation of org.eclipse.core.runtime.IAdapterFactory
named "foo.BarAdapterFactory" that is referenced in an extension:
<extension
point="org.eclipse.core.runtime.adapters">
<factory
class="foo.BarAdapterFactory"
adaptableType="...">
<adapter type="..."/>
</factory>
</extension>
This reference to "foo.BarAdapterFactory" shows up in the search results.
I also have an implementation of org.eclipse.ui.INewWizard named
"foo.BarWizard" that is referenced in another extension:
<extension
point="org.eclipse.ui.newWizards">
<category
id="..."
name="%..."
parentCategory="..."/>
<wizard
id="..."
name="%..."
icon="..."
category="...">
<description>%...</description>
<class class="foo.BarWizard">
<parameter name="xxx" value="true"/>
<parameter name="yyy" value="40" />
</class>
</wizard>
</extension>
This reference to "foo.BarWizard" does *not* show up in the search results.
Is this a bug? Or am I expecting too much?
Thanks.
Brian
Re: search results vs. plugin.xml [message #334060 is a reply to message #334059] Fri, 16 January 2009 16:07 Go to previous messageGo to next message
This looks like a bug. Can you file a bug against PDE with a small test
case?
~ Chris
Re: search results vs. plugin.xml [message #334064 is a reply to message #334060] Fri, 16 January 2009 20:40 Go to previous message
> case?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=261404
Thanks.
Brian
Previous Topic:Re: pde headless build error
Next Topic:How to force something into the UI thread
Current Time: Thu Jul 17 10:07:21 EDT 2025
Powered by FUDForum. Page generated in 0.07137 seconds
