Home » Eclipse Projects » Eclipse Platform » Login and then load plugins based on permissions.
Login and then load plugins based on permissions. [message #334057] Fri, 16 January 2009 14:24 Go to next message
Originally posted by: kathir.atc.tcs.com
I am trying to create an RCP application wher the user will login and then
based on his role the application functionalities are loaded.
I would like to use the equinox security implementation to do the login but
i am not sure how to load the plugin functionalities based on his role.
Here are the two approaches i thought of.
First Approach :
1. Application plugin - Login ( want to use Equinox Security )
2. Retrieve the Role of the user
3. Set the activities ( Eclipse Activity ) based on the Role.
Second Approach :
1. Application plugin - Login ( Equinox Security )
2. Retrieve the Role of the user and write the XSLT Transform files.
I do not know whether the second approach is right or not because i could nt
really get the sample xslt transform from the eclipse cvs to work and didnt
get any response from the newsgroup either.
So if anyone could throw some light on this, that will really help me
understand the Equinox Secuirty and Transform.
Kathir.
Re: Login and then load plugins based on permissions. [message #334081 is a reply to message #334057] Mon, 19 January 2009 12:59 Go to previous messageGo to next message
Check out http://eclipse-jaas.sourceforge.net/ which was looking at a
similar approach, I believe.
as for the sample transforms, in the past I was able to run them using
the instructions from http://wiki.eclipse.org/Equinox_Transforms
When you try and run, which plugins are in your workspace? What does
your transform file look like?
PW
Paul Webster
Re: Login and then load plugins based on permissions. [message #334098 is a reply to message #334081] Tue, 20 January 2009 13:02 Go to previous messageGo to next message
Hi Paul,
Thanks for the pointer to the eclipse-jaas , i will have a look at it.
For the XSLT Transform ,
I had the following plugins in my workspace
org.eclipse.osgi
org.eclipse.equinox.transforms.hook
org.eclipse.equinox.transforms.xslt
and my application plugin.
The xslt file had the following
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="actionSet[@id='com.seq.diagnostics.PlateActionSets]" >
<actionSet>
<xsl:attribute name="visible">true</xsl:attribute>
<xsl:copy-of select="node()|@*[not(name()='visible')]" />
</actionSet>
</xsl:template>
<xsl:template match="node()|@*">
<xsl:copy>
<xsl:apply-templates select="node()|@*"/>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
and the tranform.csv file had
com\.seq\.diagnostics,plugin\.xml,/actionSetDefault.xslt
I had the
osgi.framework.extensions=org.eclipse.equinox.transforms.hoo k
and the start level for the xslt and my application plugin with @1\:start
But when i run the application i dont see the actionset visible.
Kathir.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:gl2flb$ag5$1@build.eclipse.org...
> as for the sample transforms, in the past I was able to run them using the
> When you try and run, which plugins are in your workspace? What does your
> PW
> Paul Webster
Re: Login and then load plugins based on permissions. [message #334099 is a reply to message #334098] Tue, 20 January 2009 13:51 Go to previous messageGo to next message
Kathir wrote:
> Hi Paul,
^^^ typo?
> I had the
Did you copy out all of the working code from
org.eclipse.equinox.transforms.xslt.plugin? That's the plugin that uses
org.eclipse.equinox.transforms.hook, org.eclipse.equinox.transforms.xslt
to do the transform.
PW
Paul Webster
Re: Login and then load plugins based on permissions. [message #334100 is a reply to message #334099] Tue, 20 January 2009 17:15 Go to previous messageGo to next message
I fixed the typo on the xslt.
The xslt plugin does not have anything except the registerSevice code
Properties properties = new Properties();
properties.put("equinox.transformerType", "xslt"); //$NON-NLS-1$
//$NON-NLS-2$
registration = context.registerService(URL.class.getName(),
context.getBundle().getEntry("/transform.csv"), properties); //$NON-NLS-1$
I had copied the same lines to my activator class but no luck.
Kathir.
news:gl573i$4ka$1@build.eclipse.org...
> Kathir wrote:
>> Hi Paul,
>> <xsl:template
> ^^^ typo?
>> I had the
> PW
> Paul Webster
Re: Login and then load plugins based on permissions. [message #334101 is a reply to message #334099] Tue, 20 January 2009 18:34 Go to previous messageGo to next message
I have looked into the eclipse-jaas from the sourceforge. Its basically
installing plugins if the user is a authorized user.
But in my case, i have to disable commands and views based on the user
permissions. And also i cannot create plugins for each view and command,
that will get me 100s of plugins.
I think, if i can get the xslt constructed based on the User Permissions ,
the application will have the authroized extensions installed in the
application.
Please correct me if i am wrong on this.
Kathir.
> Kathir wrote:
>> Hi Paul,
>> <xsl:template
> ^^^ typo?
>> I had the
> PW
> Paul Webster
Re: Login and then load plugins based on permissions. [message #334102 is a reply to message #334101] Tue, 20 January 2009 18:40 Go to previous messageGo to next message
We are simply extending the expression framework and add declartive
checks to user privileges. You can look at an example application i've
created [1,2,3].
Tom
[1] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/plugin.xml
[2] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/internal/LoginSourceProvider.java
[3] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationadmin/plugin.x ml
> application.
> Kathir.
>> Kathir wrote:
>>> Hi Paul,
>>> <xsl:template
>> ^^^ typo?
>>> I had the
>> PW
>> Paul Webster
Re: Login and then load plugins based on permissions. [message #334103 is a reply to message #334102] Tue, 20 January 2009 19:12 Go to previous messageGo to next message
Hi Tom,
The LoginSourceProvider set the SOURCE_USER_GROUP to the user's group and
based on the this group type , the CommandHandler is enabled or disabled. -
Will it be possible to write a trojan plugin to make this commands enabled ,
i am just thinking whether it will be possible.
How do we do this for the views and perspectives?.
BR,
Kathir.
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gl5ne1$e3g$1@build.eclipse.org...
> created [1,2,3].
> Tom
>> application.
>> Kathir.
>>> Kathir wrote:
>>>> Hi Paul,
>>>> <xsl:template
>>> ^^^ typo?
>>>> I had the
>>>> @1\:start
>>> PW
>>> Paul Webster
Re: Login and then load plugins based on permissions. [message #334104 is a reply to message #334103] Tue, 20 January 2009 19:24 Go to previous messageGo to next message
Kathir schrieb:
> Hi Tom,
Sure but the same is true for the XSLT solution :-) and even JAAS I
guess because I could install bundles using the OSGi-Console/OSGi-API
myself any time.
In the end its always the same problem and the only real solution I know
of is to use a 3-tier setup and the application-server controls that the
user is not executing commands it is not allowed, not getting data it is
not allowed to see, ... . The client-side privileges are nice because it
helps users to only see actions, forms they are allowed to.
If someone highjacks the system the user can execute the command locally
but in the end the server denies to e.g. the creation. The same is true
for views, forms, ... if the system is hacked the user might see views
but because the server doesn't deliver data the user can't see any thing.
I think expressions can also be used on activities but I'm not 100% sure.
Tom
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Login and then load plugins based on permissions. [message #334118 is a reply to message #334104] Wed, 21 January 2009 08:54 Go to previous messageGo to next message
Yes, that was added in 3.4. With tweaks to your TriggerPointAdvisor,
expression enabled activities can be set up to be high priority (i.e. if
an expression based activity returns false it is disabled, no matter how
many other activities return true).
There's some information in Help>Help Contents>Platform Plug-in
Developer Guide and a starting point in bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201052
PW
Paul Webster
Re: Login and then load plugins based on permissions. [message #334119 is a reply to message #334100] Wed, 21 January 2009 09:00 Go to previous messageGo to next message
> //$NON-NLS-2$
I think you said you started everything, that's probably the same as the
example:
osgi.bundles=org.eclipse.equinox.common@2\:start,org.eclipse.update.configurator@3\:start,org.eclipse.core.runtime@start,org.eclipse.equinox.transforms.xslt@1:\start,org.eclipse.equinox.transforms.xslt.plugin@1:\start
Where did you get the transforms bundles from? AFAIK they now live in
/cvsroot/rt - org.eclipse.equinox/components/bundles
Paul Webster
Re: Login and then load plugins based on permissions. [message #334120 is a reply to message #334119] Wed, 21 January 2009 09:21 Go to previous messageGo to next message
I checked out the 3 plugins,
org.eclipse.equinox.transforms.hook (/cvsroot/rt)
org.eclipse.equinox.transforms.xslt (/cvsroot/rt)
org.eclipse.osgi (/cvsroot/rt)
org.eclipse.equinox.transforms.xslt.plugin (/cvsroot/eclipse
equinox-incubator)
Then I updated the /org.eclipse.equinox.transforms.xslt.plugin/XSLT
Transform Launch.launch to include all the plugins and launched it. It
processed the CSV files in
org.eclipse.equinox.internal.transforms.CSVParser.parse(URL)
You can set a breakpoint in there to see if your CSV is getting parsed.
Then really, it's about getting your plugin to include all of the things
from *.xslt.plugin (which works).
PW
Paul Webster
Re: Login and then load plugins based on permissions. [message #334135 is a reply to message #334120] Wed, 21 January 2009 16:23 Go to previous messageGo to next message
Hi Paul,
I repeated the same steps to make the transforms work. But no luck for me.
I have attached the transform_source.zip which contains two plugins.
1.com.transform.example
2. com.transform.example.transformme
I did all the checkout and copied the xslt.plugin stuff to the
com.transform.example plugin Activator. But when i run the app i dont see
the actionset visible (coming from the com.transform.example.transformme )
on the application.
When i did the debug it parses the CSV file but the plugin.xml never gets
transformed. Please help !
BR,
Kathir.
news:gl7bkv$15g$1@build.eclipse.org...
> equinox-incubator)
> PW
> Paul Webster
Re: Login and then load plugins based on permissions. [message #334138 is a reply to message #334102] Wed, 21 January 2009 18:15 Go to previous messageGo to next message
Hi Tom,
I followed the expressions approach to enable/disable commands. But it does
not seem to work.
I used enabledWhen insteadof activeWhen but no matter what i set to the
variable it never gets enabled.
<enabledWhen>
<with
variable="com.sequenom.ivd.users.factory.ADD_USER">
<equals
value="true">
</equals>
</with>
</enabledWhen>
I returned the map with com.sequenom.ivd.users.factory.ADD_USER = true but
the command is not enabled. What am i doing wrong.
Kathir.
> created [1,2,3].
> Tom
>> application.
>> Kathir.
>>> Kathir wrote:
>>>> Hi Paul,
>>>> <xsl:template
>>> ^^^ typo?
>>>> I had the
>>>> @1\:start
>>> PW
>>> Paul Webster
Re: Login and then load plugins based on permissions. [message #334141 is a reply to message #334138] Wed, 21 January 2009 19:13 Go to previous message
and if i use activeWhen it is always enabled.
<activeWhen>
<with
<equals
value="true">
</equals>
</with>
</activeWhen>
in the source provider
public static final String ADD_USER =
"com.sequenom.ivd.users.factory.ADD_USER";
public Map getCurrentState()
HashMap<String, Object> map = new HashMap<String, Object>();
map.put(ADD_USER, "false");
return map;
IT is enabled in this case even though i return false for the variable.
"Kathir" <kathir@atc.tcs.com> wrote in message
news:gl8abd$7a4$1@build.eclipse.org...
> Hi Tom,
> does not seem to work.
> <enabledWhen>
> <with
> <equals
> value="true">
> </equals>
> </with>
> </enabledWhen>
> Kathir.
>> created [1,2,3].
>> Tom
>>> application.
>>> Kathir.
>>>> Kathir wrote:
>>>>> Hi Paul,
>>>>> <xsl:template
>>>> ^^^ typo?
>>>>> I had the
>>>>> @1\:start
>>>> uses
>>>> PW
>>>> Paul Webster
Previous Topic:Eclipse and Ant tasks
Next Topic:[EUT] Class path list check
Current Time: Sun Jul 27 12:53:32 EDT 2025
Powered by FUDForum. Page generated in 0.08089 seconds
