Home » Eclipse Projects » Eclipse Platform » Status Bar and setMessage
Status Bar and setMessage [message #334051] Fri, 16 January 2009 10:52 Go to next message
I have an action that can take a while to complete so I wanted to put some
feedback in the status bar showing when the action started and when it
completed.
The main problem is that this code only causes "Pasting Completed" to be
shown. Any ideas as to get this code to show "Pasting Started" at the
beginning, then do the file copying, and show Pasting Completed at the
end?
Just to see what would happen, I removed the last "Pasted Completed" line
and ran it. The run method did all its work and then showed "Pasting
Started" when it was done. Anyway, not sure why setMessage seems to be
called last no matter where it is in the program flow. Any suggestions?
pasteAction = new Action(){
public void run(){
getViewSite().getActionBars().getStatusLineManager().setMess age( "Pasting
Started");
// do some work that could take a while
Completed");
Re: Status Bar and setMessage [message #334053 is a reply to message #334051] Fri, 16 January 2009 11:05 Go to previous messageGo to next message
Originally posted by: subs._nospam_consertum.com
Looks like you are running your code in the UI thread and thus blocking
any updates. You should be running your long-running code in another
thread, or use a Job to do it.
Andy wrote:
> some feedback in the status bar showing when the action started and when
> it completed.
> end?
> line and ran it. The run method did all its work and then showed
> "Pasting Started" when it was done. Anyway, not sure why setMessage
> seems to be called last no matter where it is in the program flow. Any
> suggestions? Thanks,
> public void run(){
> Started");
> Completed");
Derek
Re: Status Bar and setMessage [message #334054 is a reply to message #334051] Fri, 16 January 2009 11:05 Go to previous messageGo to next message
Have you looked at progress monitor ?
Manu
Re: Status Bar and setMessage [message #334078 is a reply to message #334053] Mon, 19 January 2009 10:14 Go to previous messageGo to next message
I made the code look like the following:
public void run(){
Job myjob = new Job("A Job") {
protected IStatus run(IProgressMonitor monitor) {
System.out.println("In the background job");
getViewSite().getActionBars().getStatusLineManager().setMess age( "Start
Pasting");
return Status.OK_STATUS;
myjob.setPriority(Job.SHORT);
myjob.schedule();
Completed");
But now this time I get a thread access violation in addition to it
appearing to run at the end of the method instead of the beginning. Is
there a different way to do this? Yes, I do have this running in a class
that extends ViewPart. If this doesn't work as a job how would I run it?
Why would it be blocked? Thanks,
Andy
> Andy wrote:
>> it completed.
>> end?
>> public void run(){
>> Started");
>> Completed");
Re: Status Bar and setMessage [message #334096 is a reply to message #334078] Tue, 20 January 2009 10:56 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
You've got the wrong thing in the job. You need to place the long running
work in the run method of the job and the "Start" code should be invoked
after scheduling the job. Wrap the "Completed" code in a Display.asyncExec
call and put it in the jobs run method after the long running work.
"Andy " <andrewnbenjamin@hotmail.com> wrote in message
news:26c2ecc53c6641797339d5b48dec3886$1@www.eclipse.org...
> public void run(){
> Pasting");
> myjob.schedule();
> Completed");
> Andy
> > Andy wrote:
> >> Hi,
when
> >> it completed.
be
> >> end?
> >> public void run(){
> >> Started");
> >> Completed");
Re: Status Bar and setMessage [message #334122 is a reply to message #334096] Wed, 21 January 2009 10:06 Go to previous messageGo to next message
Dave,
Thanks for the suggestions. The issue that I am having is that Job
doesn't appear to work because it yields a thread error. I switched to
using a UIJob and that allowed it to run, but the side effect was that
Eclipse appeared not to fork and run the UI and the thread in parallel,
but instead to just execute down the job path and ignore the rest of the
code in the UI thread.
My code looks like this now:
Pasting");
System.out.println("At the beginning");
UIJob job = new UIJob("My Job") {
public IStatus runInUIThread(IProgressMonitor monitor) {
System.out.println("In the job");
// Do the long running work here
job.schedule(); // start as soon as possible
PlatformUI.getWorkbench().getDisplay().asyncExec((Runnable)j ob);
getViewSite().getActionBars().getStatusLineManager().setMess age( "End
Pasting");
System.out.println("At the end");
When I look at the console the output is
At the beginning
In the job
and then when all the stuff completes in the job "Start Pasting", not "End
Pasting", shows up in the status line.
So there are still two problems
1) How do I get the status bar to update at the beginning of the method so
that it displays "Start Pasting" *prior* to me doing the copy? Whether I
used another thread or not it still won't display feedback to the user
while it does the work, only after everything is done.
2) Why doesn't async execute like it should? Instead it just goes down
the new thread path and that is it.
At this point am I doing something wrong or is this a bug?
Andy
>> public void run(){
>> Pasting");
>> myjob.schedule();
>> Completed");
>> Andy
>> > Andy wrote:
>> >> Hi,
> when
>> >> it completed.
> be
>> >> end?
>> >> public void run(){
>> >> Started");
>> >> Completed");
Re: Status Bar and setMessage [message #334124 is a reply to message #334122] Wed, 21 January 2009 10:40 Go to previous message
You are scheduling and executing the job. You should only be doing one of
these. Long running processes should not be executed on the UI thread.
When the process is executing, your UI will be frozen. The UI thread should
only be used when you need to access a UI element. This would include
setting the message on the status line. If the results of the long running
code need to be displayed on the GUI, you will need to wrap the UI updates
in a runnable that gets passed to Display.asyncExec().
UIJob job = new UIJob() {
public IStatus run(IProgressMonitor monitor) {
//do the long running work here
Runnable results = new Runnable() {
public void run(){
// update UI elements here;
statusLineManager.setMessage("End Pasting");
display.asyncExec(results);
job.schedule();
news:96ffaa211fcefc497e6b2b91538c91ed$1@www.eclipse.org...
> Dave,
> Pasting");
> Pasting");
> At the beginning
> In the job
> Andy
running
Display.asyncExec
> >> public void run(){
> >> Pasting");
> >> myjob.schedule();
> >> Completed");
class
it?
> >> Andy
blocking
> >> > Andy wrote:
> >> >> Hi,
put
> > when
> >> >> it completed.
to
> > be
the
the
> >> >> end?
Any
> >> >> public void run(){
> >> >> Started");
> >> >> Completed");
Previous Topic:javadoc cannot be showed correctly
Next Topic:Access to the workspace on the ntfs from linux eclipse
Current Time: Thu Oct 30 16:33:29 EDT 2025
Powered by FUDForum. Page generated in 0.27305 seconds
