| Re: Where to write initialization code before plug-in launches? [message #334045 is a reply to message #334040] |
Fri, 16 January 2009 09:59  |
kaprasi wrote:
> Hello,
> I am writing an eclipse plug-in.
> Is there some init method / some other place where I can add some code
> when eclipse launches and before start() method of my plug-in class gets
> called?
> Thanks.
What are you seeking to do? What is wrong with using the start() method
of your plug-in or another plug-in of yours?
In Eclipse, there is the org.eclipse.ui.startup extension point that can
be used to initialize things when the workbench is brought up, but I
discourage people from using this. The problem is that people think they
have the most important plug-in in the world when in reality, they
should play nicely with everyone else.
~ Chris
FUDForum. Page generated in 0.03443 seconds
