Home » Eclipse Projects » Eclipse Platform » Help getting popup menu item to appear based on a System Property
Help getting popup menu item to appear based on a System Property [message #334031] |
Fri, 16 January 2009 00:06  |
Hello all,
I have a menu item on the right-click Popup Menu for a Project in the
Project Explorer. I want this menu item to only appear if a certain
System Property is set; I don't care what value it is set to, only that it
is set. Does anybody have any suggestions?
I've been searching the newsgroups, searching Google, experimenting with
my plugin.xml, and looking at the Eclipse source code trying to get it to
work.
I initially thought I'd use <visibility> and <systemProperty ...> on my
<objectContribution> to org.eclipse.ui.popupMenus. It doesn't seem like I
can specify in the plugin.xml that the value of the System Property is
anything or, in the negative case, that the value is not set or null. In
reading the source code of
org.eclipse.ui.internal.ActionExpression.SystemPropertyExpre ssion, I see
that isEnabledFor() always returns false when the System Property is not
set. So, I can set the visibility like so:
<visibility>
<not>
<systemProperty name="some.property" value=""/>
</not>
</and>
However, if the System Property is set to something, this doesn't work at
all.
My next thought was to use <filter> on my <objectContribution> and write
a custom org.eclipse.ui.IActionFilter. However, this doesn't seem like it
will work, because the menu item acts on a Project which already has an
IActionFilter.
The last thought was that I could set write code in my plugin activator
that would set the System Property to "" if it wasn't already set before.
Of course, this won't work, because the plugin with my action won't be
activated yet. This wouldn't work anyway, since in my case, the System
Property being set to a valid value is required for the plugin activator
to work correctly. So, I can't even make my plugin an EarlyStartup plugin
to set the System Property to "".
Thanks in advance!
Nadeem Aboobaker
Re: Help getting popup menu item to appear based on a System Property [message #334047 is a reply to message #334031] |
Fri, 16 January 2009 09:59   |
I forgot to mention that I'm using Eclipse 3.3.2.
Also, I tried EarlyStartup as mentioned in my "last thought" after
re-organizing my code so the plugin activation does not depend on the
system property. I can now get the exact behavior I want, but it seems a
little hacky to use EarlyStartup for this (and plus, I'm not sure what
side effects are caused by EarlyStartup for my plugin).
So, I'm still searching for the "right" solution, if it exists. :)
Thanks!
Nadeem
Nadeem Aboobaker wrote:
> Hello all,
> work.
> <visibility>
> <not>
> </not>
> </and>
> all.
> IActionFilter.
> Thanks in advance!
> Nadeem Aboobaker
Re: Help getting popup menu item to appear based on a System Property [message #334049 is a reply to message #334031] |
Fri, 16 January 2009 10:37   |
Also, I tried the EarlyStartup option mentioned in the "last thought" of
the original post. After, re-organizing my code so that the plugin
initialization does not require the system property, the visibility of the
popup menu item works as I want. However, it seems a little "hacky" to
use EarlyStartup (not to mention, I'm unsure of the side effects of
EarlyStartup on my plugin).
So, does anybody know the right solution, if it exists?
Nadeem Aboobaker
> Hello all,
> work.
> <visibility>
> <not>
> </not>
> </and>
> all.
> IActionFilter.
> Thanks in advance!
> Nadeem Aboobaker
Re: Help getting popup menu item to appear based on a System Property [message #334061 is a reply to message #334058] |
Fri, 16 January 2009 17:20  |
>> Hello all,
>> it is set. Does anybody have any suggestions?
> Talking about "System Property", so:
> what about simply using java.lang.System.getProperty("myproperty") or do
> I miss something here?
> Regards, Norbert
I wasn't aware that you could specify Java code in a plugin.xml. Can you
please give an example of how I would use System.getProperty() in my
org.eclipse.ui.popupMenus extension in plugin.xml?
Nadeem
Current Time: Sat Aug 23 03:46:26 EDT 2025
Powered by FUDForum. Page generated in 0.03994 seconds
